Date/Time: Sat, 21 Dec 2024 18:23:40 +0000
counter for price change per bar
View Count: 1156
[2015-03-07 11:57:01] |
User66292 - Posts: 12 |
hello make please the counter for price changes per bar thanks |
[2015-03-08 09:14:23] |
Zosimus - Posts: 345 |
Take a look here: Price changes count within bar |
[2015-03-10 00:56:57] |
We checked the Countdown Timer study with Price Change Bars and it does work properly. Make sure you are using the current version of Sierra Chart.
