Date/Time: Sat, 21 Dec 2024 18:39:16 +0000
USDX Feed
View Count: 1092
[2015-02-26 12:14:47] |
BBFX1966 - Posts: 18 |
I can graph (intra-day) USDX but when I add it to a Quote Board I just see zero"s. CAn you help thanks Bernard |
[2015-02-26 19:21:59] |
On the Intraday chart for USDX, do you see a [M] after the symbol?
[2015-02-26 19:40:10] |
Hi No I do not see anywhere on the chart or menu bar, etc |
[2015-02-26 19:43:32] |
Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-27 12:52:13] |
I've tried your suggestion but still do not see the M after USDX |
[2015-02-27 14:54:54] |
I've also noticed that the price doesn't update on my chart. It's actually frozen |
[2015-02-27 16:39:01] |
Restart Sierra Chart. Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-27 18:19:42] |
Software version: 1224 | 2015-02-27 13:18:05 Uses New Spreadsheets | 2015-02-27 13:18:05 Usage end date: 2016-06-18 | 2015-02-27 13:18:05 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-02-27 13:18:05 Active service: SC Forex Data (FXCM) | 2015-02-27 13:18:05 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-02-27 13:18:05 2015-02-27 13:18:05 Local computer clock time | 2015-02-27 13:18:05 2015-02-27 18:18:05 GMT time | 2015-02-27 13:18:05 2015-02-27 13:18:05 Time zone adjusted time | 2015-02-27 13:18:05 Time difference to server time: 3 seconds. | 2015-02-27 13:18:05 Program path: C:\SierraChart\ | 2015-02-27 13:18:05 Data Files path: C:\SierraChart\Data\ | 2015-02-27 13:18:05 OS Version Number: 6.1 | 2015-02-27 13:18:05 Locale Information: C | 2015-02-27 13:18:05 Checking for new symbol settings for fxcm | 2015-02-27 13:18:05 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-02-27 13:18:05 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-02-27 13:18:05 Symbol settings are up-to-date for fxcm | 2015-02-27 13:18:05 Files to Open on Start up | Opening file: TGC_Intra.cht | 2015-02-27 13:18:08 Files to Open on Start up | Opening file: TGC_dly.cht | 2015-02-27 13:18:10 Chart: USDOLLAR Daily #1 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: EURUSD Daily #2 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: GBPUSD Daily #3 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: AUDUSD Daily #4 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: NZDUSD Daily #5 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: USDJPY Daily #6 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: USDCAD Daily #7 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: USDCHF Daily #8 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: EURJPY Daily #9 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: EURAUD Daily #10 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: EURCAD Daily #11 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: EURGBP Daily #12 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: EURCHF Daily #13 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: EURNZD Daily #14 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: GBPJPY Daily #15 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: AUDJPY Daily #16 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:10 * Chart: NZDJPY Daily #17 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:11 * Chart: CADJPY Daily #18 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:11 * Chart: GBPAUD Daily #19 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:11 * Chart: GBPCAD Daily #20 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:11 * Chart: GBPNZD Daily #21 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:12 * Chart: AUDNZD Daily #22 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:12 * Chart: USDSGD Daily #23 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:12 * Chart: USDHKD Daily #24 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:12 * Chart: USDCNH Daily #25 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:12 * Chart: USDMXN Daily #26 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:12 * Chart: USDTRY Daily #27 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:12 * Chart: USDZAR Daily #28 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:12 * Chart: EURCZK Daily #29 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:12 * Chart: EURTRY Daily #30 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:12 * HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-02-27 13:18:12 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-02-27 13:18:12 Intraday data recording state for symbol EURUSD is set to download pending. | 2015-02-27 13:18:13 HD Request # 2 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2015-02-27 13:18:13 HD Request # 2 | Download start Date-Time: 2015-02-27 11:09:47.0 | 2015-02-27 13:18:13 HD Request # 2 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:13 Intraday data recording state for symbol USDOLLAR is set to download pending. | 2015-02-27 13:18:13 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:13 Socket (2) | Connected. | 2015-02-27 13:18:13 HD Request # 2 | Sending historical data logon request message. | 2015-02-27 13:18:13 Intraday data recording state for symbol USDCHF is set to download pending. | 2015-02-27 13:18:13 Intraday data recording state for symbol USDJPY is set to download pending. | 2015-02-27 13:18:13 Intraday data recording state for symbol USDCAD is set to download pending. | 2015-02-27 13:18:13 Intraday data recording state for symbol NZDUSD is set to download pending. | 2015-02-27 13:18:13 Intraday data recording state for symbol AUDUSD is set to download pending. | 2015-02-27 13:18:13 Intraday data recording state for symbol GBPUSD is set to download pending. | 2015-02-27 13:18:13 Intraday data recording state for symbol EURCAD is set to download pending. | 2015-02-27 13:18:13 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:47. Record interval: 1. Symbol: EURUSD | 2015-02-27 13:18:13 Intraday data recording state for symbol EURGBP is set to download pending. | 2015-02-27 13:18:13 Intraday data recording state for symbol EURAUD is set to download pending. | 2015-02-27 13:18:13 Intraday data recording state for symbol USDCNH is set to download pending. | 2015-02-27 13:18:13 HD Request # 2 | Decompressing data. | 2015-02-27 13:18:13 Intraday data recording state for symbol EURJPY is set to download pending. | 2015-02-27 13:18:13 HD Request # 2 | Receiving Intraday data for EURUSD starting at 2015-02-27 11:09:47 | 2015-02-27 13:18:13 HD Request # 2 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:47 | 2015-02-27 13:18:13 Intraday data recording state for symbol EURCHF is set to download pending. | 2015-02-27 13:18:14 Socket (2) | Shutdown and closed. | 2015-02-27 13:18:14 The network socket for historical data has been closed. | 2015-02-27 13:18:14 Intraday data recording state for symbol EURTRY is set to download pending. | 2015-02-27 13:18:14 HD Request # 2 | Historical data for EURUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-02-27 13:18:14 HD Request # 2 | Received 3353 records from 2015-02-27 11:09:47 to 2015-02-27 13:18:16 (2.1 hours) and wrote 3353 records for EURUSD | 2015-02-27 13:18:14 HD Request # 2 | Intraday download COMPLETE for EURUSD. Completion time: 0s. Unique request ID: 1 | 2015-02-27 13:18:14 Removed historical data download ID 1 | 2015-02-27 13:18:14 HD Request # 3 | Downloading Intraday chart data for USDOLLAR to the file USDOLLAR.scid. Service: fxcm | 2015-02-27 13:18:14 HD Request # 3 | Download start Date-Time: 2015-02-27 11:09:34.0 | 2015-02-27 13:18:14 HD Request # 3 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:14 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:14 Intraday data recording state for symbol USDTRY is set to download pending. | 2015-02-27 13:18:14 Socket (3) | Connected. | 2015-02-27 13:18:14 HD Request # 3 | Sending historical data logon request message. | 2015-02-27 13:18:14 Intraday data recording state for symbol USDZAR is set to download pending. | 2015-02-27 13:18:14 Intraday data recording state for symbol USDMXN is set to download pending. | 2015-02-27 13:18:14 Intraday data recording state for symbol USDSGD is set to download pending. | 2015-02-27 13:18:15 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:34. Record interval: 1. Symbol: USDOLLAR | 2015-02-27 13:18:15 Intraday data recording state for symbol AUDNZD is set to download pending. | 2015-02-27 13:18:15 HD Request # 3 | Decompressing data. | 2015-02-27 13:18:15 HD Request # 3 | Receiving Intraday data for USDOLLAR starting at 2015-02-27 11:09:34 | 2015-02-27 13:18:15 HD Request # 3 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:34 | 2015-02-27 13:18:15 Socket (3) | Shutdown and closed. | 2015-02-27 13:18:15 The network socket for historical data has been closed. | 2015-02-27 13:18:15 Intraday data recording state for symbol GBPNZD is set to download pending. | 2015-02-27 13:18:15 HD Request # 3 | Historical data for USDOLLAR is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-02-27 13:18:15 HD Request # 3 | Received 489 records from 2015-02-27 11:09:34 to 2015-02-27 13:17:59 (2.1 hours) and wrote 489 records for USDOLLAR | 2015-02-27 13:18:15 HD Request # 3 | Intraday download COMPLETE for USDOLLAR. Completion time: 1s. Unique request ID: 2 | 2015-02-27 13:18:15 Removed historical data download ID 2 | 2015-02-27 13:18:15 HD Request # 4 | Downloading Intraday chart data for USDCHF to the file USDCHF.scid. Service: fxcm | 2015-02-27 13:18:15 HD Request # 4 | Download start Date-Time: 2015-02-27 11:09:46.0 | 2015-02-27 13:18:16 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:16 Intraday data recording state for symbol GBPCAD is set to download pending. | 2015-02-27 13:18:16 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:16 Intraday data recording state for symbol GBPAUD is set to download pending. | 2015-02-27 13:18:16 Intraday data recording state for symbol GBPJPY is set to download pending. | 2015-02-27 13:18:16 Socket (4) | Connected. | 2015-02-27 13:18:16 HD Request # 4 | Sending historical data logon request message. | 2015-02-27 13:18:16 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:46. Record interval: 1. Symbol: USDCHF | 2015-02-27 13:18:16 HD Request # 4 | Decompressing data. | 2015-02-27 13:18:16 HD Request # 4 | Receiving Intraday data for USDCHF starting at 2015-02-27 11:09:46 | 2015-02-27 13:18:16 HD Request # 4 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:46 | 2015-02-27 13:18:16 Intraday data recording state for symbol AUDJPY is set to download pending. | 2015-02-27 13:18:16 Intraday data recording state for symbol AUDCAD is set to download pending. | 2015-02-27 13:18:16 Intraday data recording state for symbol EURCZK is set to download pending. | 2015-02-27 13:18:16 Intraday data recording state for symbol SPX500 is set to download pending. | 2015-02-27 13:18:16 Intraday data recording state for symbol USDX is set to download pending. | 2015-02-27 13:18:16 Socket (4) | Shutdown and closed. | 2015-02-27 13:18:17 The network socket for historical data has been closed. | 2015-02-27 13:18:17 Intraday data recording state for symbol USOil is set to download pending. | 2015-02-27 13:18:19 HD Request # 4 | Historical data for USDCHF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-02-27 13:18:19 HD Request # 4 | Received 1370 records from 2015-02-27 11:09:46 to 2015-02-27 13:18:18 (2.1 hours) and wrote 1370 records for USDCHF | 2015-02-27 13:18:20 HD Request # 4 | Intraday download COMPLETE for USDCHF. Completion time: 5s. Unique request ID: 3 | 2015-02-27 13:18:20 Removed historical data download ID 3 | 2015-02-27 13:18:20 HD Request # 5 | Downloading Intraday chart data for USDJPY to the file USDJPY.scid. Service: fxcm | 2015-02-27 13:18:20 HD Request # 5 | Download start Date-Time: 2015-02-27 11:09:47.0 | 2015-02-27 13:18:21 HD Request # 5 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:21 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:21 Socket (5) | Connected. | 2015-02-27 13:18:21 HD Request # 5 | Sending historical data logon request message. | 2015-02-27 13:18:21 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:47. Record interval: 1. Symbol: USDJPY | 2015-02-27 13:18:21 HD Request # 5 | Decompressing data. | 2015-02-27 13:18:21 HD Request # 5 | Receiving Intraday data for USDJPY starting at 2015-02-27 11:09:47 | 2015-02-27 13:18:21 HD Request # 5 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:47 | 2015-02-27 13:18:21 Socket (5) | Shutdown and closed. | 2015-02-27 13:18:21 The network socket for historical data has been closed. | 2015-02-27 13:18:21 HD Request # 5 | Historical data for USDJPY is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-02-27 13:18:22 HD Request # 5 | Received 3505 records from 2015-02-27 11:09:47 to 2015-02-27 13:18:21 (2.1 hours) and wrote 3505 records for USDJPY | 2015-02-27 13:18:22 HD Request # 5 | Intraday download COMPLETE for USDJPY. Completion time: 2s. Unique request ID: 4 | 2015-02-27 13:18:22 Removed historical data download ID 4 | 2015-02-27 13:18:22 HD Request # 6 | Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: fxcm | 2015-02-27 13:18:22 HD Request # 6 | Download start Date-Time: 2015-02-27 11:09:46.0 | 2015-02-27 13:18:22 HD Request # 6 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:22 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:22 Intraday data recording state for symbol XAUUSD is set to download pending. | 2015-02-27 13:18:22 Socket (6) | Connected. | 2015-02-27 13:18:22 HD Request # 6 | Sending historical data logon request message. | 2015-02-27 13:18:22 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:46. Record interval: 1. Symbol: USDCAD | 2015-02-27 13:18:22 HD Request # 6 | Decompressing data. | 2015-02-27 13:18:22 HD Request # 6 | Receiving Intraday data for USDCAD starting at 2015-02-27 11:09:46 | 2015-02-27 13:18:22 HD Request # 6 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:46 | 2015-02-27 13:18:22 Socket (6) | Shutdown and closed. | 2015-02-27 13:18:22 The network socket for historical data has been closed. | 2015-02-27 13:18:22 HD Request # 6 | Historical data for USDCAD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-02-27 13:18:22 HD Request # 6 | Received 2619 records from 2015-02-27 11:09:46 to 2015-02-27 13:18:21 (2.1 hours) and wrote 2619 records for USDCAD | 2015-02-27 13:18:22 HD Request # 6 | Intraday download COMPLETE for USDCAD. Completion time: 0s. Unique request ID: 5 | 2015-02-27 13:18:22 Removed historical data download ID 5 | 2015-02-27 13:18:22 HD Request # 7 | Downloading Intraday chart data for NZDUSD to the file NZDUSD.scid. Service: fxcm | 2015-02-27 13:18:22 HD Request # 7 | Download start Date-Time: 2015-02-27 11:09:39.0 | 2015-02-27 13:18:22 HD Request # 7 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:22 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:22 Socket (7) | Connected. | 2015-02-27 13:18:22 HD Request # 7 | Sending historical data logon request message. | 2015-02-27 13:18:22 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:39. Record interval: 1. Symbol: NZDUSD | 2015-02-27 13:18:22 SC Forex Data (FXCM) | Connecting to the server ds5.sierracharts.com. Port 443 | 2015-02-27 13:18:22 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:22 HD Request # 7 | Decompressing data. | 2015-02-27 13:18:22 Socket (8) | Connected. | 2015-02-27 13:18:22 SC Forex Data (FXCM) | Connected to server. | 2015-02-27 13:18:22 SC Forex Data (FXCM) | Sending logon request message. | 2015-02-27 13:18:22 HD Request # 7 | Receiving Intraday data for NZDUSD starting at 2015-02-27 11:09:39 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Server Name: SC Real-Time Server. | 2015-02-27 13:18:23 HD Request # 7 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:39 | 2015-02-27 13:18:23 Socket (7) | Shutdown and closed. | 2015-02-27 13:18:23 The network socket for historical data has been closed. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Successfully connected. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USDOLLAR. ID: 1 | 2015-02-27 13:18:23 HD Request # 7 | Re-requesting historical data for NZDUSD to get the latest data since the download was started while not connected to primary service. | 2015-02-27 13:18:23 HD Request # 7 | Received 1794 records from 2015-02-27 11:09:39 to 2015-02-27 13:18:21 (2.1 hours) and wrote 1794 records for NZDUSD | 2015-02-27 13:18:23 HD Request # 8 | Downloading Intraday chart data for NZDUSD to the file NZDUSD.scid. Service: fxcm | 2015-02-27 13:18:23 HD Request # 8 | Download start Date-Time: 2015-02-27 13:18:21.0 | 2015-02-27 13:18:23 HD Request # 8 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:23 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: AUDUSD. ID: 3 | 2015-02-27 13:18:23 Intraday data recording state for symbol AUDUSD is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPUSD. ID: 4 | 2015-02-27 13:18:23 Intraday data recording state for symbol GBPUSD is set to download pending. | 2015-02-27 13:18:23 Socket (9) | Connected. | 2015-02-27 13:18:23 HD Request # 8 | Sending historical data logon request message. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: EURCAD. ID: 5 | 2015-02-27 13:18:23 Intraday data recording state for symbol EURCAD is set to download pending. | 2015-02-27 13:18:23 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2015-02-27 13:18:21. Record interval: 1. Symbol: NZDUSD | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: EURGBP. ID: 6 | 2015-02-27 13:18:23 Intraday data recording state for symbol EURGBP is set to download pending. | 2015-02-27 13:18:23 HD Request # 8 | Decompressing data. | 2015-02-27 13:18:23 HD Request # 8 | Receiving Intraday data for NZDUSD starting at 2015-02-27 13:18:21 | 2015-02-27 13:18:23 HD Request # 8 | Timestamp of first Intraday data file record written: 2015-02-27 13:18:21 | 2015-02-27 13:18:23 Socket (9) | Shutdown and closed. | 2015-02-27 13:18:23 The network socket for historical data has been closed. | 2015-02-27 13:18:23 HD Request # 8 | Received 1 record from 2015-02-27 13:18:21 to 2015-02-27 13:18:21 (0.0 seconds) and wrote 1 record for NZDUSD | 2015-02-27 13:18:23 HD Request # 8 | Intraday download COMPLETE for NZDUSD. Completion time: 0s. Unique request ID: 6 | 2015-02-27 13:18:23 Removed historical data download ID 6 | 2015-02-27 13:18:23 Real-time Intraday chart data file updates started for NZDUSD | 2015-02-27 13:18:23 HD Request # 9 | Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: fxcm | 2015-02-27 13:18:23 HD Request # 9 | Download start Date-Time: 2015-02-27 11:09:37.0 | 2015-02-27 13:18:23 HD Request # 9 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:23 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: EURAUD. ID: 7 | 2015-02-27 13:18:23 Intraday data recording state for symbol EURAUD is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USDCNH. ID: 8 | 2015-02-27 13:18:23 Intraday data recording state for symbol USDCNH is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: EURNZD. ID: 9 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: EURTRY. ID: 10 | 2015-02-27 13:18:23 Intraday data recording state for symbol EURTRY is set to download pending. | 2015-02-27 13:18:23 Socket (10) | Connected. | 2015-02-27 13:18:23 HD Request # 9 | Sending historical data logon request message. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USDTRY. ID: 11 | 2015-02-27 13:18:23 Intraday data recording state for symbol USDTRY is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USDZAR. ID: 12 | 2015-02-27 13:18:23 Intraday data recording state for symbol USDZAR is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USDMXN. ID: 13 | 2015-02-27 13:18:23 Intraday data recording state for symbol USDMXN is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USDSGD. ID: 14 | 2015-02-27 13:18:23 Intraday data recording state for symbol USDSGD is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: SPX500. ID: 15 | 2015-02-27 13:18:23 Intraday data recording state for symbol SPX500 is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USDX. ID: 16 | 2015-02-27 13:18:23 Intraday data recording state for symbol USDX is set to download pending. | 2015-02-27 13:18:23 Intraday data recording state for symbol USDOLLAR is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: AUDJPY. ID: 17 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPCAD. ID: 18 | 2015-02-27 13:18:23 HD Request # 9 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:37. Record interval: 1. Symbol: AUDUSD | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USOil. ID: 19 | 2015-02-27 13:18:23 Intraday data recording state for symbol USOil is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: EURUSD. ID: 20 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: XAUUSD. ID: 21 | 2015-02-27 13:18:23 Intraday data recording state for symbol XAUUSD is set to download pending. | 2015-02-27 13:18:23 Chart: GBPUSD Daily #3 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:23 * Real-time data for symbol USDX is currently unavailable. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: NZDJPY. ID: 22 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: AUDNZD. ID: 23 | 2015-02-27 13:18:23 Intraday data recording state for symbol AUDNZD is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPNZD. ID: 24 | 2015-02-27 13:18:23 Intraday data recording state for symbol GBPNZD is set to download pending. | 2015-02-27 13:18:23 Intraday data recording state for symbol GBPCAD is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPAUD. ID: 25 | 2015-02-27 13:18:23 Intraday data recording state for symbol GBPAUD is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: GBPJPY. ID: 26 | 2015-02-27 13:18:23 Intraday data recording state for symbol GBPJPY is set to download pending. | 2015-02-27 13:18:23 Intraday data recording state for symbol AUDJPY is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: AUDCAD. ID: 27 | 2015-02-27 13:18:23 Intraday data recording state for symbol AUDCAD is set to download pending. | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: NZDUSD. ID: 2 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USDJPY. ID: 28 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USDHKD. ID: 29 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USDCAD. ID: 30 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: USDCHF. ID: 31 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: EURCZK. ID: 32 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: EURCHF. ID: 33 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: EURJPY. ID: 34 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: CADJPY. ID: 35 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: NAS100. ID: 36 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: US30. ID: 37 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: UKOIL. ID: 38 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: COPPER. ID: 39 | 2015-02-27 13:18:23 Chart: EURAUD Daily #10 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:23 * HD Request # 9 | Decompressing data. | 2015-02-27 13:18:23 Chart: EURCAD Daily #11 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:23 * Intraday data recording state for symbol EURUSD is set to download pending. | 2015-02-27 13:18:23 Intraday data recording state for symbol USDCHF is set to download pending. | 2015-02-27 13:18:23 Intraday data recording state for symbol USDJPY is set to download pending. | 2015-02-27 13:18:23 Intraday data recording state for symbol USDCAD is set to download pending. | 2015-02-27 13:18:23 Intraday data recording state for symbol EURJPY is set to download pending. | 2015-02-27 13:18:23 Intraday data recording state for symbol EURCHF is set to download pending. | 2015-02-27 13:18:23 HD Request # 9 | Receiving Intraday data for AUDUSD starting at 2015-02-27 11:09:37 | 2015-02-27 13:18:23 HD Request # 9 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:37 | 2015-02-27 13:18:23 Chart: EURGBP Daily #12 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:23 * Chart: GBPAUD Daily #19 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:23 * SC Forex Data (FXCM) | Starting real-time market data updates for: AUS200. ID: 40 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: HKG33. ID: 41 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: JPN225. ID: 42 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: FRA40. ID: 43 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: GER30. ID: 44 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: UK100. ID: 45 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: ESP35. ID: 46 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: ITA40. ID: 47 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: SUI30. ID: 48 | 2015-02-27 13:18:23 SC Forex Data (FXCM) | Starting real-time market data updates for: EUSTX50. ID: 49 | 2015-02-27 13:18:23 Intraday data recording state for symbol EURCZK is set to download pending. | 2015-02-27 13:18:23 Chart: EURNZD Daily #14 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:23 * Chart: GBPJPY Daily #15 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:23 * Socket (10) | Shutdown and closed. | 2015-02-27 13:18:23 The network socket for historical data has been closed. | 2015-02-27 13:18:23 HD Request # 9 | Received 2528 records from 2015-02-27 11:09:37 to 2015-02-27 13:18:25 (2.1 hours) and wrote 2528 records for AUDUSD | 2015-02-27 13:18:23 Added 3 Time and Sales records to Intraday data file for AUDUSD after download. | 2015-02-27 13:18:23 HD Request # 9 | Intraday download COMPLETE for AUDUSD. Completion time: 0s. Unique request ID: 7 | 2015-02-27 13:18:23 Removed historical data download ID 7 | 2015-02-27 13:18:23 Real-time Intraday chart data file updates started for AUDUSD | 2015-02-27 13:18:23 HD Request # 10 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2015-02-27 13:18:24 HD Request # 10 | Download start Date-Time: 2015-02-27 11:09:47.0 | 2015-02-27 13:18:24 HD Request # 10 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:24 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:24 Chart: EURTRY Daily #30 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:24 * Socket (11) | Connected. | 2015-02-27 13:18:24 HD Request # 10 | Sending historical data logon request message. | 2015-02-27 13:18:24 Chart: EURUSD Daily #2 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:24 * Chart: AUDUSD Daily #4 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:24 * HD Request # 10 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:47. Record interval: 1. Symbol: GBPUSD | 2015-02-27 13:18:24 Chart: NZDUSD Daily #5 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:24 * HD Request # 10 | Decompressing data. | 2015-02-27 13:18:24 Chart: USDJPY Daily #6 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:24 * HD Request # 10 | Receiving Intraday data for GBPUSD starting at 2015-02-27 11:09:47 | 2015-02-27 13:18:24 HD Request # 10 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:47 | 2015-02-27 13:18:24 Chart: EURJPY Daily #9 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:24 * Chart: AUDJPY Daily #16 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:24 * Chart: NZDJPY Daily #17 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:24 * Socket (11) | Shutdown and closed. | 2015-02-27 13:18:24 The network socket for historical data has been closed. | 2015-02-27 13:18:24 Chart: USDCAD Daily #7 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:24 * HD Request # 10 | Received 3178 records from 2015-02-27 11:09:47 to 2015-02-27 13:18:26 (2.1 hours) and wrote 3178 records for GBPUSD | 2015-02-27 13:18:24 HD Request # 10 | Intraday download COMPLETE for GBPUSD. Completion time: 0s. Unique request ID: 8 | 2015-02-27 13:18:24 Removed historical data download ID 8 | 2015-02-27 13:18:24 Real-time Intraday chart data file updates started for GBPUSD | 2015-02-27 13:18:24 HD Request # 11 | Downloading Intraday chart data for EURCAD to the file EURCAD.scid. Service: fxcm | 2015-02-27 13:18:24 HD Request # 11 | Download start Date-Time: 2015-02-27 11:09:47.0 | 2015-02-27 13:18:24 HD Request # 11 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:24 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:24 Socket (12) | Connected. | 2015-02-27 13:18:24 HD Request # 11 | Sending historical data logon request message. | 2015-02-27 13:18:24 HD Request # 11 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:47. Record interval: 1. Symbol: EURCAD | 2015-02-27 13:18:24 Chart: CADJPY Daily #18 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:24 * HD Request # 11 | Decompressing data. | 2015-02-27 13:18:24 HD Request # 11 | Receiving Intraday data for EURCAD starting at 2015-02-27 11:09:47 | 2015-02-27 13:18:24 HD Request # 11 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:47 | 2015-02-27 13:18:24 Socket (12) | Shutdown and closed. | 2015-02-27 13:18:24 The network socket for historical data has been closed. | 2015-02-27 13:18:24 Chart: GBPCAD Daily #20 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:24 * HD Request # 11 | Received 4482 records from 2015-02-27 11:09:47 to 2015-02-27 13:18:26 (2.1 hours) and wrote 4482 records for EURCAD | 2015-02-27 13:18:24 HD Request # 11 | Intraday download COMPLETE for EURCAD. Completion time: 0s. Unique request ID: 9 | 2015-02-27 13:18:24 Removed historical data download ID 9 | 2015-02-27 13:18:24 Real-time Intraday chart data file updates started for EURCAD | 2015-02-27 13:18:24 HD Request # 12 | Downloading Intraday chart data for EURGBP to the file EURGBP.scid. Service: fxcm | 2015-02-27 13:18:24 HD Request # 12 | Download start Date-Time: 2015-02-27 11:09:43.0 | 2015-02-27 13:18:24 HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:24 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:24 Socket (13) | Connected. | 2015-02-27 13:18:24 HD Request # 12 | Sending historical data logon request message. | 2015-02-27 13:18:24 HD Request # 12 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:43. Record interval: 1. Symbol: EURGBP | 2015-02-27 13:18:24 HD Request # 12 | Decompressing data. | 2015-02-27 13:18:24 HD Request # 12 | Receiving Intraday data for EURGBP starting at 2015-02-27 11:09:43 | 2015-02-27 13:18:24 HD Request # 12 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:43 | 2015-02-27 13:18:24 Socket (13) | Shutdown and closed. | 2015-02-27 13:18:24 The network socket for historical data has been closed. | 2015-02-27 13:18:24 HD Request # 12 | Received 3345 records from 2015-02-27 11:09:43 to 2015-02-27 13:18:26 (2.1 hours) and wrote 3345 records for EURGBP | 2015-02-27 13:18:24 Added 3 Time and Sales records to Intraday data file for EURGBP after download. | 2015-02-27 13:18:24 HD Request # 12 | Intraday download COMPLETE for EURGBP. Completion time: 0s. Unique request ID: 10 | 2015-02-27 13:18:24 Removed historical data download ID 10 | 2015-02-27 13:18:24 Real-time Intraday chart data file updates started for EURGBP | 2015-02-27 13:18:24 HD Request # 13 | Downloading Intraday chart data for EURAUD to the file EURAUD.scid. Service: fxcm | 2015-02-27 13:18:24 HD Request # 13 | Download start Date-Time: 2015-02-27 11:09:46.0 | 2015-02-27 13:18:24 HD Request # 13 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:24 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:24 Socket (14) | Connected. | 2015-02-27 13:18:24 HD Request # 13 | Sending historical data logon request message. | 2015-02-27 13:18:24 HD Request # 13 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:46. Record interval: 1. Symbol: EURAUD | 2015-02-27 13:18:25 HD Request # 13 | Decompressing data. | 2015-02-27 13:18:25 HD Request # 13 | Receiving Intraday data for EURAUD starting at 2015-02-27 11:09:46 | 2015-02-27 13:18:25 HD Request # 13 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:46 | 2015-02-27 13:18:25 Chart: GBPNZD Daily #21 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:25 * Socket (14) | Shutdown and closed. | 2015-02-27 13:18:25 The network socket for historical data has been closed. | 2015-02-27 13:18:25 HD Request # 13 | Received 3443 records from 2015-02-27 11:09:46 to 2015-02-27 13:18:26 (2.1 hours) and wrote 3443 records for EURAUD | 2015-02-27 13:18:25 Added 3 Time and Sales records to Intraday data file for EURAUD after download. | 2015-02-27 13:18:25 HD Request # 13 | Intraday download COMPLETE for EURAUD. Completion time: 1s. Unique request ID: 11 | 2015-02-27 13:18:25 Removed historical data download ID 11 | 2015-02-27 13:18:25 Real-time Intraday chart data file updates started for EURAUD | 2015-02-27 13:18:25 HD Request # 14 | Downloading Intraday chart data for USDCNH to the file USDCNH.scid. Service: fxcm | 2015-02-27 13:18:25 HD Request # 14 | Download start Date-Time: 2015-02-27 11:09:34.0 | 2015-02-27 13:18:25 HD Request # 14 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:25 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:25 Socket (15) | Connected. | 2015-02-27 13:18:25 HD Request # 14 | Sending historical data logon request message. | 2015-02-27 13:18:25 Chart: USDCHF Daily #8 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:25 * HD Request # 14 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:34. Record interval: 1. Symbol: USDCNH | 2015-02-27 13:18:25 HD Request # 14 | Decompressing data. | 2015-02-27 13:18:25 HD Request # 14 | Receiving Intraday data for USDCNH starting at 2015-02-27 11:09:34 | 2015-02-27 13:18:25 HD Request # 14 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:34 | 2015-02-27 13:18:25 Socket (15) | Shutdown and closed. | 2015-02-27 13:18:25 The network socket for historical data has been closed. | 2015-02-27 13:18:25 HD Request # 14 | Received 481 records from 2015-02-27 11:09:34 to 2015-02-27 13:17:42 (2.1 hours) and wrote 481 records for USDCNH | 2015-02-27 13:18:25 HD Request # 14 | Intraday download COMPLETE for USDCNH. Completion time: 0s. Unique request ID: 12 | 2015-02-27 13:18:25 Removed historical data download ID 12 | 2015-02-27 13:18:25 Real-time Intraday chart data file updates started for USDCNH | 2015-02-27 13:18:25 HD Request # 15 | Downloading Historical Daily chart data for EURNZD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:25 HD Request # 15 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:25 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:25 Socket (16) | Connected. | 2015-02-27 13:18:25 HD Request # 15 | Sending historical data logon request message. | 2015-02-27 13:18:25 HD Request # 15 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:25 HD Request # 15 | Decompressing data. | 2015-02-27 13:18:25 HD Request # 15 | Receiving historical Daily data for EURNZD starting at 2015-02-26 | 2015-02-27 13:18:25 Writing historical Daily data for EURNZD to the file EURNZD.dly | 2015-02-27 13:18:25 Socket (16) | Shutdown and closed. | 2015-02-27 13:18:25 The network socket for historical data has been closed. | 2015-02-27 13:18:25 HD Request # 15 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for EURNZD | 2015-02-27 13:18:25 HD Request # 15 | Daily download COMPLETE for EURNZD. Completion time: 0s. Unique request ID: 13 | 2015-02-27 13:18:25 Removed historical data download ID 13 | 2015-02-27 13:18:25 HD Request # 16 | Downloading Intraday chart data for EURJPY to the file EURJPY.scid. Service: fxcm | 2015-02-27 13:18:25 HD Request # 16 | Download start Date-Time: 2015-02-27 11:09:47.0 | 2015-02-27 13:18:25 HD Request # 16 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:25 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:25 Socket (17) | Connected. | 2015-02-27 13:18:25 HD Request # 16 | Sending historical data logon request message. | 2015-02-27 13:18:25 HD Request # 16 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:47. Record interval: 1. Symbol: EURJPY | 2015-02-27 13:18:25 HD Request # 16 | Decompressing data. | 2015-02-27 13:18:25 HD Request # 16 | Receiving Intraday data for EURJPY starting at 2015-02-27 11:09:47 | 2015-02-27 13:18:25 HD Request # 16 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:47 | 2015-02-27 13:18:25 Chart: EURNZD Daily #14 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:26 * Socket (17) | Shutdown and closed. | 2015-02-27 13:18:26 The network socket for historical data has been closed. | 2015-02-27 13:18:26 HD Request # 16 | Received 3883 records from 2015-02-27 11:09:47 to 2015-02-27 13:18:27 (2.1 hours) and wrote 3883 records for EURJPY | 2015-02-27 13:18:26 Added 6 Time and Sales records to Intraday data file for EURJPY after download. | 2015-02-27 13:18:26 HD Request # 16 | Intraday download COMPLETE for EURJPY. Completion time: 1s. Unique request ID: 14 | 2015-02-27 13:18:26 Removed historical data download ID 14 | 2015-02-27 13:18:26 Real-time Intraday chart data file updates started for EURJPY | 2015-02-27 13:18:26 HD Request # 17 | Downloading Intraday chart data for EURCHF to the file EURCHF.scid. Service: fxcm | 2015-02-27 13:18:26 HD Request # 17 | Download start Date-Time: 2015-02-27 11:09:47.0 | 2015-02-27 13:18:26 HD Request # 17 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:26 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:26 Socket (18) | Connected. | 2015-02-27 13:18:26 HD Request # 17 | Sending historical data logon request message. | 2015-02-27 13:18:26 HD Request # 17 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:47. Record interval: 1. Symbol: EURCHF | 2015-02-27 13:18:26 HD Request # 17 | Decompressing data. | 2015-02-27 13:18:26 HD Request # 17 | Receiving Intraday data for EURCHF starting at 2015-02-27 11:09:47 | 2015-02-27 13:18:26 HD Request # 17 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:47 | 2015-02-27 13:18:26 Socket (18) | Shutdown and closed. | 2015-02-27 13:18:26 The network socket for historical data has been closed. | 2015-02-27 13:18:26 HD Request # 17 | Received 1934 records from 2015-02-27 11:09:47 to 2015-02-27 13:18:26 (2.1 hours) and wrote 1934 records for EURCHF | 2015-02-27 13:18:26 HD Request # 17 | Intraday download COMPLETE for EURCHF. Completion time: 0s. Unique request ID: 15 | 2015-02-27 13:18:26 Removed historical data download ID 15 | 2015-02-27 13:18:26 Real-time Intraday chart data file updates started for EURCHF | 2015-02-27 13:18:26 HD Request # 18 | Downloading Intraday chart data for EURTRY to the file EURTRY.scid. Service: fxcm | 2015-02-27 13:18:26 HD Request # 18 | Download start Date-Time: 2015-02-27 11:09:41.0 | 2015-02-27 13:18:26 HD Request # 18 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:26 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:26 Socket (19) | Connected. | 2015-02-27 13:18:26 HD Request # 18 | Sending historical data logon request message. | 2015-02-27 13:18:26 HD Request # 18 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:41. Record interval: 1. Symbol: EURTRY | 2015-02-27 13:18:26 HD Request # 18 | Decompressing data. | 2015-02-27 13:18:26 HD Request # 18 | Receiving Intraday data for EURTRY starting at 2015-02-27 11:09:41 | 2015-02-27 13:18:26 HD Request # 18 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:41 | 2015-02-27 13:18:26 Socket (19) | Shutdown and closed. | 2015-02-27 13:18:26 The network socket for historical data has been closed. | 2015-02-27 13:18:26 HD Request # 18 | Received 2264 records from 2015-02-27 11:09:41 to 2015-02-27 13:18:27 (2.1 hours) and wrote 2264 records for EURTRY | 2015-02-27 13:18:26 HD Request # 18 | Intraday download COMPLETE for EURTRY. Completion time: 0s. Unique request ID: 16 | 2015-02-27 13:18:26 Removed historical data download ID 16 | 2015-02-27 13:18:26 Real-time Intraday chart data file updates started for EURTRY | 2015-02-27 13:18:26 HD Request # 19 | Downloading Intraday chart data for USDTRY to the file USDTRY.scid. Service: fxcm | 2015-02-27 13:18:26 HD Request # 19 | Download start Date-Time: 2015-02-27 11:09:43.0 | 2015-02-27 13:18:26 HD Request # 19 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:26 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:26 Socket (20) | Connected. | 2015-02-27 13:18:26 HD Request # 19 | Sending historical data logon request message. | 2015-02-27 13:18:26 HD Request # 19 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:43. Record interval: 1. Symbol: USDTRY | 2015-02-27 13:18:26 HD Request # 19 | Decompressing data. | 2015-02-27 13:18:26 HD Request # 19 | Receiving Intraday data for USDTRY starting at 2015-02-27 11:09:43 | 2015-02-27 13:18:26 HD Request # 19 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:43 | 2015-02-27 13:18:26 Socket (20) | Shutdown and closed. | 2015-02-27 13:18:26 The network socket for historical data has been closed. | 2015-02-27 13:18:26 HD Request # 19 | Received 2025 records from 2015-02-27 11:09:43 to 2015-02-27 13:18:24 (2.1 hours) and wrote 2025 records for USDTRY | 2015-02-27 13:18:26 HD Request # 19 | Intraday download COMPLETE for USDTRY. Completion time: 0s. Unique request ID: 17 | 2015-02-27 13:18:26 Removed historical data download ID 17 | 2015-02-27 13:18:26 Real-time Intraday chart data file updates started for USDTRY | 2015-02-27 13:18:26 HD Request # 20 | Downloading Intraday chart data for USDZAR to the file USDZAR.scid. Service: fxcm | 2015-02-27 13:18:26 HD Request # 20 | Download start Date-Time: 2015-02-27 11:09:47.0 | 2015-02-27 13:18:26 HD Request # 20 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:26 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:26 Socket (21) | Connected. | 2015-02-27 13:18:26 HD Request # 20 | Sending historical data logon request message. | 2015-02-27 13:18:26 HD Request # 20 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:47. Record interval: 1. Symbol: USDZAR | 2015-02-27 13:18:26 HD Request # 20 | Decompressing data. | 2015-02-27 13:18:26 HD Request # 20 | Receiving Intraday data for USDZAR starting at 2015-02-27 11:09:47 | 2015-02-27 13:18:27 HD Request # 20 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:47 | 2015-02-27 13:18:27 Socket (21) | Shutdown and closed. | 2015-02-27 13:18:27 The network socket for historical data has been closed. | 2015-02-27 13:18:27 HD Request # 20 | Received 2280 records from 2015-02-27 11:09:47 to 2015-02-27 13:18:17 (2.1 hours) and wrote 2280 records for USDZAR | 2015-02-27 13:18:27 HD Request # 20 | Intraday download COMPLETE for USDZAR. Completion time: 0s. Unique request ID: 18 | 2015-02-27 13:18:27 Removed historical data download ID 18 | 2015-02-27 13:18:27 Real-time Intraday chart data file updates started for USDZAR | 2015-02-27 13:18:27 HD Request # 21 | Downloading Intraday chart data for USDMXN to the file USDMXN.scid. Service: fxcm | 2015-02-27 13:18:27 HD Request # 21 | Download start Date-Time: 2015-02-27 11:09:45.0 | 2015-02-27 13:18:27 HD Request # 21 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:27 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:27 Socket (22) | Connected. | 2015-02-27 13:18:27 HD Request # 21 | Sending historical data logon request message. | 2015-02-27 13:18:27 HD Request # 21 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:45. Record interval: 1. Symbol: USDMXN | 2015-02-27 13:18:27 HD Request # 21 | Decompressing data. | 2015-02-27 13:18:27 HD Request # 21 | Receiving Intraday data for USDMXN starting at 2015-02-27 11:09:45 | 2015-02-27 13:18:27 HD Request # 21 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:45 | 2015-02-27 13:18:27 Socket (22) | Shutdown and closed. | 2015-02-27 13:18:27 The network socket for historical data has been closed. | 2015-02-27 13:18:27 HD Request # 21 | Received 2675 records from 2015-02-27 11:09:45 to 2015-02-27 13:18:24 (2.1 hours) and wrote 2675 records for USDMXN | 2015-02-27 13:18:27 HD Request # 21 | Intraday download COMPLETE for USDMXN. Completion time: 0s. Unique request ID: 19 | 2015-02-27 13:18:27 Removed historical data download ID 19 | 2015-02-27 13:18:27 Real-time Intraday chart data file updates started for USDMXN | 2015-02-27 13:18:27 HD Request # 22 | Downloading Intraday chart data for USDSGD to the file USDSGD.scid. Service: fxcm | 2015-02-27 13:18:27 HD Request # 22 | Download start Date-Time: 2015-02-20 16:59:00.0 | 2015-02-27 13:18:27 HD Request # 22 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:27 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:27 Socket (23) | Connected. | 2015-02-27 13:18:27 HD Request # 22 | Sending historical data logon request message. | 2015-02-27 13:18:27 HD Request # 22 | Requesting Intraday data. Start Date-Time: 2015-02-20 16:59:00. Record interval: 1. Symbol: USDSGD | 2015-02-27 13:18:27 HD Request # 22 | Decompressing data. | 2015-02-27 13:18:27 HD Request # 22 | Receiving Intraday data for USDSGD starting at 2015-02-20 16:59:00 | 2015-02-27 13:18:27 HD Request # 22 | Timestamp of first Intraday data file record written: 2015-02-20 16:59:00 | 2015-02-27 13:18:27 Socket (23) | Shutdown and closed. | 2015-02-27 13:18:27 The network socket for historical data has been closed. | 2015-02-27 13:18:27 HD Request # 22 | Received 1 record from 2015-02-20 16:59:00 to 2015-02-20 16:59:00 (0.0 seconds) and wrote 1 record for USDSGD | 2015-02-27 13:18:27 HD Request # 22 | Intraday download COMPLETE for USDSGD. Completion time: 0s. Unique request ID: 20 | 2015-02-27 13:18:27 Removed historical data download ID 20 | 2015-02-27 13:18:27 Real-time Intraday chart data file updates started for USDSGD | 2015-02-27 13:18:27 HD Request # 23 | Downloading Intraday chart data for AUDNZD to the file AUDNZD.scid. Service: fxcm | 2015-02-27 13:18:27 HD Request # 23 | Download start Date-Time: 2015-02-27 11:09:39.0 | 2015-02-27 13:18:27 HD Request # 23 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:27 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:27 Socket (24) | Connected. | 2015-02-27 13:18:27 HD Request # 23 | Sending historical data logon request message. | 2015-02-27 13:18:27 HD Request # 23 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:39. Record interval: 1. Symbol: AUDNZD | 2015-02-27 13:18:27 HD Request # 23 | Decompressing data. | 2015-02-27 13:18:28 HD Request # 23 | Receiving Intraday data for AUDNZD starting at 2015-02-27 11:09:39 | 2015-02-27 13:18:28 HD Request # 23 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:39 | 2015-02-27 13:18:28 Socket (24) | Shutdown and closed. | 2015-02-27 13:18:28 The network socket for historical data has been closed. | 2015-02-27 13:18:28 HD Request # 23 | Received 1452 records from 2015-02-27 11:09:39 to 2015-02-27 13:18:07 (2.1 hours) and wrote 1452 records for AUDNZD | 2015-02-27 13:18:28 HD Request # 23 | Intraday download COMPLETE for AUDNZD. Completion time: 1s. Unique request ID: 21 | 2015-02-27 13:18:28 Removed historical data download ID 21 | 2015-02-27 13:18:28 Real-time Intraday chart data file updates started for AUDNZD | 2015-02-27 13:18:28 HD Request # 24 | Downloading Intraday chart data for GBPNZD to the file GBPNZD.scid. Service: fxcm | 2015-02-27 13:18:28 HD Request # 24 | Download start Date-Time: 2015-02-27 11:09:46.0 | 2015-02-27 13:18:28 HD Request # 24 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:28 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:28 Socket (25) | Connected. | 2015-02-27 13:18:28 HD Request # 24 | Sending historical data logon request message. | 2015-02-27 13:18:28 HD Request # 24 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:46. Record interval: 1. Symbol: GBPNZD | 2015-02-27 13:18:28 Chart: AUDNZD Daily #22 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:28 * HD Request # 24 | Decompressing data. | 2015-02-27 13:18:28 HD Request # 24 | Receiving Intraday data for GBPNZD starting at 2015-02-27 11:09:46 | 2015-02-27 13:18:28 HD Request # 24 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:46 | 2015-02-27 13:18:28 Chart: USDMXN Daily #26 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:28 * Socket (25) | Shutdown and closed. | 2015-02-27 13:18:28 The network socket for historical data has been closed. | 2015-02-27 13:18:28 HD Request # 24 | Received 3056 records from 2015-02-27 11:09:46 to 2015-02-27 13:18:28 (2.1 hours) and wrote 3056 records for GBPNZD | 2015-02-27 13:18:28 Added 1 Time and Sales records to Intraday data file for GBPNZD after download. | 2015-02-27 13:18:28 HD Request # 24 | Intraday download COMPLETE for GBPNZD. Completion time: 0s. Unique request ID: 22 | 2015-02-27 13:18:28 Removed historical data download ID 22 | 2015-02-27 13:18:28 Real-time Intraday chart data file updates started for GBPNZD | 2015-02-27 13:18:28 HD Request # 25 | Downloading Intraday chart data for GBPCAD to the file GBPCAD.scid. Service: fxcm | 2015-02-27 13:18:28 HD Request # 25 | Download start Date-Time: 2015-02-27 11:09:46.0 | 2015-02-27 13:18:28 HD Request # 25 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:28 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:28 Socket (26) | Connected. | 2015-02-27 13:18:28 HD Request # 25 | Sending historical data logon request message. | 2015-02-27 13:18:28 HD Request # 25 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:46. Record interval: 1. Symbol: GBPCAD | 2015-02-27 13:18:29 HD Request # 25 | Decompressing data. | 2015-02-27 13:18:29 HD Request # 25 | Receiving Intraday data for GBPCAD starting at 2015-02-27 11:09:46 | 2015-02-27 13:18:29 HD Request # 25 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:46 | 2015-02-27 13:18:29 Socket (26) | Shutdown and closed. | 2015-02-27 13:18:29 The network socket for historical data has been closed. | 2015-02-27 13:18:29 HD Request # 25 | Received 3787 records from 2015-02-27 11:09:46 to 2015-02-27 13:18:28 (2.1 hours) and wrote 3787 records for GBPCAD | 2015-02-27 13:18:29 HD Request # 25 | Intraday download COMPLETE for GBPCAD. Completion time: 1s. Unique request ID: 23 | 2015-02-27 13:18:29 Removed historical data download ID 23 | 2015-02-27 13:18:29 Real-time Intraday chart data file updates started for GBPCAD | 2015-02-27 13:18:29 HD Request # 26 | Downloading Intraday chart data for GBPAUD to the file GBPAUD.scid. Service: fxcm | 2015-02-27 13:18:29 HD Request # 26 | Download start Date-Time: 2015-02-27 11:09:46.0 | 2015-02-27 13:18:29 HD Request # 26 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:29 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:29 Socket (27) | Connected. | 2015-02-27 13:18:29 HD Request # 26 | Sending historical data logon request message. | 2015-02-27 13:18:29 HD Request # 26 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:46. Record interval: 1. Symbol: GBPAUD | 2015-02-27 13:18:29 HD Request # 26 | Decompressing data. | 2015-02-27 13:18:29 HD Request # 26 | Receiving Intraday data for GBPAUD starting at 2015-02-27 11:09:46 | 2015-02-27 13:18:29 HD Request # 26 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:46 | 2015-02-27 13:18:29 Socket (27) | Shutdown and closed. | 2015-02-27 13:18:29 The network socket for historical data has been closed. | 2015-02-27 13:18:29 HD Request # 26 | Received 3706 records from 2015-02-27 11:09:46 to 2015-02-27 13:18:31 (2.1 hours) and wrote 3706 records for GBPAUD | 2015-02-27 13:18:29 HD Request # 26 | Intraday download COMPLETE for GBPAUD. Completion time: 0s. Unique request ID: 24 | 2015-02-27 13:18:29 Removed historical data download ID 24 | 2015-02-27 13:18:29 Real-time Intraday chart data file updates started for GBPAUD | 2015-02-27 13:18:29 HD Request # 27 | Downloading Intraday chart data for GBPJPY to the file GBPJPY.scid. Service: fxcm | 2015-02-27 13:18:29 HD Request # 27 | Download start Date-Time: 2015-02-27 11:09:47.0 | 2015-02-27 13:18:29 HD Request # 27 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:29 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:29 Socket (28) | Connected. | 2015-02-27 13:18:29 HD Request # 27 | Sending historical data logon request message. | 2015-02-27 13:18:29 HD Request # 27 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:47. Record interval: 1. Symbol: GBPJPY | 2015-02-27 13:18:29 HD Request # 27 | Decompressing data. | 2015-02-27 13:18:29 HD Request # 27 | Receiving Intraday data for GBPJPY starting at 2015-02-27 11:09:47 | 2015-02-27 13:18:29 HD Request # 27 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:47 | 2015-02-27 13:18:29 Chart: USDTRY Daily #27 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:29 * Socket (28) | Shutdown and closed. | 2015-02-27 13:18:29 The network socket for historical data has been closed. | 2015-02-27 13:18:29 HD Request # 27 | Received 3958 records from 2015-02-27 11:09:47 to 2015-02-27 13:18:30 (2.1 hours) and wrote 3958 records for GBPJPY | 2015-02-27 13:18:29 HD Request # 27 | Intraday download COMPLETE for GBPJPY. Completion time: 0s. Unique request ID: 25 | 2015-02-27 13:18:29 Removed historical data download ID 25 | 2015-02-27 13:18:29 Real-time Intraday chart data file updates started for GBPJPY | 2015-02-27 13:18:29 HD Request # 28 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2015-02-27 13:18:29 HD Request # 28 | Download start Date-Time: 2015-02-27 11:09:47.0 | 2015-02-27 13:18:29 HD Request # 28 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:29 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:29 Socket (29) | Connected. | 2015-02-27 13:18:29 HD Request # 28 | Sending historical data logon request message. | 2015-02-27 13:18:29 HD Request # 28 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:47. Record interval: 1. Symbol: AUDJPY | 2015-02-27 13:18:30 HD Request # 28 | Decompressing data. | 2015-02-27 13:18:30 HD Request # 28 | Receiving Intraday data for AUDJPY starting at 2015-02-27 11:09:47 | 2015-02-27 13:18:30 HD Request # 28 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:47 | 2015-02-27 13:18:30 Socket (29) | Shutdown and closed. | 2015-02-27 13:18:30 The network socket for historical data has been closed. | 2015-02-27 13:18:30 HD Request # 28 | Received 3482 records from 2015-02-27 11:09:47 to 2015-02-27 13:18:31 (2.1 hours) and wrote 3482 records for AUDJPY | 2015-02-27 13:18:30 Added 1 Time and Sales records to Intraday data file for AUDJPY after download. | 2015-02-27 13:18:30 HD Request # 28 | Intraday download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 26 | 2015-02-27 13:18:30 Removed historical data download ID 26 | 2015-02-27 13:18:30 Real-time Intraday chart data file updates started for AUDJPY | 2015-02-27 13:18:30 HD Request # 29 | Downloading Intraday chart data for AUDCAD to the file AUDCAD.scid. Service: fxcm | 2015-02-27 13:18:30 HD Request # 29 | Download start Date-Time: 2015-02-27 11:09:44.0 | 2015-02-27 13:18:30 HD Request # 29 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:30 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:30 Socket (30) | Connected. | 2015-02-27 13:18:30 HD Request # 29 | Sending historical data logon request message. | 2015-02-27 13:18:30 HD Request # 29 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:44. Record interval: 1. Symbol: AUDCAD | 2015-02-27 13:18:30 HD Request # 29 | Decompressing data. | 2015-02-27 13:18:30 HD Request # 29 | Receiving Intraday data for AUDCAD starting at 2015-02-27 11:09:44 | 2015-02-27 13:18:30 HD Request # 29 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:44 | 2015-02-27 13:18:30 Socket (30) | Shutdown and closed. | 2015-02-27 13:18:30 The network socket for historical data has been closed. | 2015-02-27 13:18:30 HD Request # 29 | Received 3020 records from 2015-02-27 11:09:44 to 2015-02-27 13:18:31 (2.1 hours) and wrote 3020 records for AUDCAD | 2015-02-27 13:18:30 HD Request # 29 | Intraday download COMPLETE for AUDCAD. Completion time: 0s. Unique request ID: 27 | 2015-02-27 13:18:30 Removed historical data download ID 27 | 2015-02-27 13:18:30 Real-time Intraday chart data file updates started for AUDCAD | 2015-02-27 13:18:30 HD Request # 30 | Downloading Intraday chart data for EURCZK to the file EURCZK.scid. Service: fxcm | 2015-02-27 13:18:30 HD Request # 30 | Download start Date-Time: 2015-01-30 16:59:00.0 | 2015-02-27 13:18:30 HD Request # 30 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:30 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:30 Socket (31) | Connected. | 2015-02-27 13:18:30 HD Request # 30 | Sending historical data logon request message. | 2015-02-27 13:18:30 HD Request # 30 | Requesting Intraday data. Start Date-Time: 2015-01-30 16:59:00. Record interval: 1. Symbol: EURCZK | 2015-02-27 13:18:30 HD Request # 30 | Decompressing data. | 2015-02-27 13:18:31 HD Request # 30 | Receiving Intraday data for EURCZK starting at 2015-01-30 16:59:00 | 2015-02-27 13:18:31 HD Request # 30 | Timestamp of first Intraday data file record written: 2015-01-30 16:59:00 | 2015-02-27 13:18:31 Socket (31) | Shutdown and closed. | 2015-02-27 13:18:31 The network socket for historical data has been closed. | 2015-02-27 13:18:31 HD Request # 30 | Received 1 record from 2015-01-30 16:59:00 to 2015-01-30 16:59:00 (0.0 seconds) and wrote 1 record for EURCZK | 2015-02-27 13:18:31 HD Request # 30 | Intraday download COMPLETE for EURCZK. Completion time: 1s. Unique request ID: 28 | 2015-02-27 13:18:31 Removed historical data download ID 28 | 2015-02-27 13:18:31 Real-time Intraday chart data file updates started for EURCZK | 2015-02-27 13:18:31 HD Request # 31 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm | 2015-02-27 13:18:31 HD Request # 31 | Download start Date-Time: 2015-02-27 11:09:14.0 | 2015-02-27 13:18:31 HD Request # 31 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:31 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:31 Socket (32) | Connected. | 2015-02-27 13:18:31 HD Request # 31 | Sending historical data logon request message. | 2015-02-27 13:18:31 HD Request # 31 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:14. Record interval: 1. Symbol: SPX500 | 2015-02-27 13:18:31 HD Request # 31 | Decompressing data. | 2015-02-27 13:18:31 HD Request # 31 | Receiving Intraday data for SPX500 starting at 2015-02-27 11:09:14 | 2015-02-27 13:18:31 HD Request # 31 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:14 | 2015-02-27 13:18:31 Socket (32) | Shutdown and closed. | 2015-02-27 13:18:31 The network socket for historical data has been closed. | 2015-02-27 13:18:31 HD Request # 31 | Received 705 records from 2015-02-27 11:09:14 to 2015-02-27 13:18:01 (2.1 hours) and wrote 705 records for SPX500 | 2015-02-27 13:18:31 HD Request # 31 | Intraday download COMPLETE for SPX500. Completion time: 0s. Unique request ID: 29 | 2015-02-27 13:18:31 Removed historical data download ID 29 | 2015-02-27 13:18:31 Real-time Intraday chart data file updates started for SPX500 | 2015-02-27 13:18:31 HD Request # 32 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc | 2015-02-27 13:18:31 HD Request # 32 | Download start Date-Time: 2015-02-27 07:49:06.0 | 2015-02-27 13:18:31 HD Request # 32 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:31 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:31 Socket (33) | Connected. | 2015-02-27 13:18:31 HD Request # 32 | Sending historical data logon request message. | 2015-02-27 13:18:31 HD Request # 32 | Requesting Intraday data. Start Date-Time: 2015-02-27 07:49:06. Record interval: 1. Symbol: USDX | 2015-02-27 13:18:31 HD Request # 32 | Decompressing data. | 2015-02-27 13:18:31 HD Request # 32 | Receiving Intraday data for USDX starting at 2015-02-27 07:49:06 | 2015-02-27 13:18:31 HD Request # 32 | Timestamp of first Intraday data file record written: 2015-02-27 07:49:06 | 2015-02-27 13:18:31 Socket (33) | Shutdown and closed. | 2015-02-27 13:18:31 The network socket for historical data has been closed. | 2015-02-27 13:18:31 HD Request # 32 | Received 18034 records from 2015-02-27 07:49:06 to 2015-02-27 13:18:32 (5.5 hours) and wrote 18034 records for USDX | 2015-02-27 13:18:31 HD Request # 32 | Intraday download COMPLETE for USDX. Completion time: 0s. Unique request ID: 30 | 2015-02-27 13:18:31 Removed historical data download ID 30 | 2015-02-27 13:18:31 Real-time Intraday chart data file updates started for USDX | 2015-02-27 13:18:31 HD Request # 33 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2015-02-27 13:18:31 HD Request # 33 | Download start Date-Time: 2015-02-27 11:09:40.0 | 2015-02-27 13:18:31 HD Request # 33 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:31 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:31 Socket (34) | Connected. | 2015-02-27 13:18:31 HD Request # 33 | Sending historical data logon request message. | 2015-02-27 13:18:31 HD Request # 33 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:40. Record interval: 1. Symbol: USOil | 2015-02-27 13:18:31 HD Request # 33 | Decompressing data. | 2015-02-27 13:18:32 HD Request # 33 | Receiving Intraday data for USOil starting at 2015-02-27 11:09:40 | 2015-02-27 13:18:32 HD Request # 33 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:40 | 2015-02-27 13:18:32 Socket (34) | Shutdown and closed. | 2015-02-27 13:18:32 The network socket for historical data has been closed. | 2015-02-27 13:18:32 HD Request # 33 | Received 2503 records from 2015-02-27 11:09:40 to 2015-02-27 13:18:34 (2.1 hours) and wrote 2503 records for USOil | 2015-02-27 13:18:32 Added 1 Time and Sales records to Intraday data file for USOil after download. | 2015-02-27 13:18:32 HD Request # 33 | Intraday download COMPLETE for USOil. Completion time: 1s. Unique request ID: 31 | 2015-02-27 13:18:32 Removed historical data download ID 31 | 2015-02-27 13:18:32 Real-time Intraday chart data file updates started for USOil | 2015-02-27 13:18:32 HD Request # 34 | Downloading Historical Daily chart data for USDOLLAR. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:32 HD Request # 34 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:32 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:32 Chart: USDHKD Daily #24 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:32 * Socket (35) | Connected. | 2015-02-27 13:18:32 HD Request # 34 | Sending historical data logon request message. | 2015-02-27 13:18:32 HD Request # 34 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:32 HD Request # 34 | Decompressing data. | 2015-02-27 13:18:32 HD Request # 34 | Receiving historical Daily data for USDOLLAR starting at 2015-02-26 | 2015-02-27 13:18:32 Writing historical Daily data for USDOLLAR to the file USDOLLAR.dly | 2015-02-27 13:18:32 Socket (35) | Shutdown and closed. | 2015-02-27 13:18:32 The network socket for historical data has been closed. | 2015-02-27 13:18:32 HD Request # 34 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for USDOLLAR | 2015-02-27 13:18:32 HD Request # 34 | Daily download COMPLETE for USDOLLAR. Completion time: 0s. Unique request ID: 32 | 2015-02-27 13:18:32 Removed historical data download ID 32 | 2015-02-27 13:18:32 HD Request # 35 | Downloading Historical Daily chart data for EURUSD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:32 HD Request # 35 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:32 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:32 Socket (36) | Connected. | 2015-02-27 13:18:32 HD Request # 35 | Sending historical data logon request message. | 2015-02-27 13:18:32 HD Request # 35 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:32 HD Request # 35 | Decompressing data. | 2015-02-27 13:18:32 HD Request # 35 | Receiving historical Daily data for EURUSD starting at 2015-02-26 | 2015-02-27 13:18:32 Writing historical Daily data for EURUSD to the file EURUSD.dly | 2015-02-27 13:18:32 Socket (36) | Shutdown and closed. | 2015-02-27 13:18:32 The network socket for historical data has been closed. | 2015-02-27 13:18:32 HD Request # 35 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for EURUSD | 2015-02-27 13:18:32 HD Request # 35 | Daily download COMPLETE for EURUSD. Completion time: 0s. Unique request ID: 33 | 2015-02-27 13:18:32 Removed historical data download ID 33 | 2015-02-27 13:18:32 HD Request # 36 | Downloading Historical Daily chart data for GBPUSD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:32 HD Request # 36 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:32 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:32 Chart: EURUSD Daily #2 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:32 * Chart: USDOLLAR Daily #1 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:32 * Socket (37) | Connected. | 2015-02-27 13:18:32 HD Request # 36 | Sending historical data logon request message. | 2015-02-27 13:18:32 HD Request # 36 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:32 HD Request # 36 | Decompressing data. | 2015-02-27 13:18:32 HD Request # 36 | Receiving historical Daily data for GBPUSD starting at 2015-02-26 | 2015-02-27 13:18:32 Writing historical Daily data for GBPUSD to the file GBPUSD.dly | 2015-02-27 13:18:32 Socket (37) | Shutdown and closed. | 2015-02-27 13:18:32 The network socket for historical data has been closed. | 2015-02-27 13:18:32 HD Request # 36 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for GBPUSD | 2015-02-27 13:18:32 HD Request # 36 | Daily download COMPLETE for GBPUSD. Completion time: 0s. Unique request ID: 34 | 2015-02-27 13:18:32 Removed historical data download ID 34 | 2015-02-27 13:18:32 HD Request # 37 | Downloading Historical Daily chart data for AUDUSD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:32 HD Request # 37 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:32 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:32 Socket (38) | Connected. | 2015-02-27 13:18:32 HD Request # 37 | Sending historical data logon request message. | 2015-02-27 13:18:32 HD Request # 37 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:32 HD Request # 37 | Decompressing data. | 2015-02-27 13:18:32 HD Request # 37 | Receiving historical Daily data for AUDUSD starting at 2015-02-26 | 2015-02-27 13:18:33 Writing historical Daily data for AUDUSD to the file AUDUSD.dly | 2015-02-27 13:18:33 Socket (38) | Shutdown and closed. | 2015-02-27 13:18:33 The network socket for historical data has been closed. | 2015-02-27 13:18:33 HD Request # 37 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for AUDUSD | 2015-02-27 13:18:33 HD Request # 37 | Daily download COMPLETE for AUDUSD. Completion time: 0s. Unique request ID: 35 | 2015-02-27 13:18:33 Removed historical data download ID 35 | 2015-02-27 13:18:33 HD Request # 38 | Downloading Historical Daily chart data for NZDUSD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:33 HD Request # 38 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:33 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:33 Socket (39) | Connected. | 2015-02-27 13:18:33 HD Request # 38 | Sending historical data logon request message. | 2015-02-27 13:18:33 HD Request # 38 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:33 Chart: GBPUSD Daily #3 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:33 * HD Request # 38 | Decompressing data. | 2015-02-27 13:18:33 HD Request # 38 | Receiving historical Daily data for NZDUSD starting at 2015-02-26 | 2015-02-27 13:18:33 Writing historical Daily data for NZDUSD to the file NZDUSD.dly | 2015-02-27 13:18:33 Socket (39) | Shutdown and closed. | 2015-02-27 13:18:33 The network socket for historical data has been closed. | 2015-02-27 13:18:33 HD Request # 38 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for NZDUSD | 2015-02-27 13:18:33 HD Request # 38 | Daily download COMPLETE for NZDUSD. Completion time: 0s. Unique request ID: 36 | 2015-02-27 13:18:33 Removed historical data download ID 36 | 2015-02-27 13:18:33 HD Request # 39 | Downloading Historical Daily chart data for USDJPY. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:33 HD Request # 39 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:33 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:33 Chart: AUDUSD Daily #4 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:33 * Socket (40) | Connected. | 2015-02-27 13:18:33 HD Request # 39 | Sending historical data logon request message. | 2015-02-27 13:18:33 Chart: NZDUSD Daily #5 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:33 * HD Request # 39 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:33 HD Request # 39 | Decompressing data. | 2015-02-27 13:18:33 HD Request # 39 | Receiving historical Daily data for USDJPY starting at 2015-02-26 | 2015-02-27 13:18:33 Writing historical Daily data for USDJPY to the file USDJPY.dly | 2015-02-27 13:18:33 Socket (40) | Shutdown and closed. | 2015-02-27 13:18:33 The network socket for historical data has been closed. | 2015-02-27 13:18:33 HD Request # 39 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for USDJPY | 2015-02-27 13:18:33 HD Request # 39 | Daily download COMPLETE for USDJPY. Completion time: 0s. Unique request ID: 37 | 2015-02-27 13:18:33 Removed historical data download ID 37 | 2015-02-27 13:18:33 HD Request # 40 | Downloading Historical Daily chart data for USDCAD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:33 HD Request # 40 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:33 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:33 Socket (41) | Connected. | 2015-02-27 13:18:33 HD Request # 40 | Sending historical data logon request message. | 2015-02-27 13:18:33 HD Request # 40 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:33 HD Request # 40 | Decompressing data. | 2015-02-27 13:18:33 HD Request # 40 | Receiving historical Daily data for USDCAD starting at 2015-02-26 | 2015-02-27 13:18:33 Writing historical Daily data for USDCAD to the file USDCAD.dly | 2015-02-27 13:18:33 Socket (41) | Shutdown and closed. | 2015-02-27 13:18:33 The network socket for historical data has been closed. | 2015-02-27 13:18:33 HD Request # 40 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for USDCAD | 2015-02-27 13:18:33 HD Request # 40 | Daily download COMPLETE for USDCAD. Completion time: 0s. Unique request ID: 38 | 2015-02-27 13:18:33 Removed historical data download ID 38 | 2015-02-27 13:18:33 HD Request # 41 | Downloading Historical Daily chart data for USDCHF. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:33 HD Request # 41 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:33 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:33 Socket (42) | Connected. | 2015-02-27 13:18:33 HD Request # 41 | Sending historical data logon request message. | 2015-02-27 13:18:33 HD Request # 41 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:33 HD Request # 41 | Decompressing data. | 2015-02-27 13:18:33 HD Request # 41 | Receiving historical Daily data for USDCHF starting at 2015-02-26 | 2015-02-27 13:18:33 Writing historical Daily data for USDCHF to the file USDCHF.dly | 2015-02-27 13:18:33 Socket (42) | Shutdown and closed. | 2015-02-27 13:18:33 The network socket for historical data has been closed. | 2015-02-27 13:18:33 HD Request # 41 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for USDCHF | 2015-02-27 13:18:33 HD Request # 41 | Daily download COMPLETE for USDCHF. Completion time: 0s. Unique request ID: 39 | 2015-02-27 13:18:33 Removed historical data download ID 39 | 2015-02-27 13:18:33 HD Request # 42 | Downloading Historical Daily chart data for EURJPY. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:33 HD Request # 42 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:33 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:33 Chart: USDJPY Daily #6 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:33 * Socket (43) | Connected. | 2015-02-27 13:18:33 HD Request # 42 | Sending historical data logon request message. | 2015-02-27 13:18:33 HD Request # 42 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:33 HD Request # 42 | Decompressing data. | 2015-02-27 13:18:33 HD Request # 42 | Receiving historical Daily data for EURJPY starting at 2015-02-26 | 2015-02-27 13:18:33 Writing historical Daily data for EURJPY to the file EURJPY.dly | 2015-02-27 13:18:33 Socket (43) | Shutdown and closed. | 2015-02-27 13:18:33 The network socket for historical data has been closed. | 2015-02-27 13:18:33 HD Request # 42 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for EURJPY | 2015-02-27 13:18:33 HD Request # 42 | Daily download COMPLETE for EURJPY. Completion time: 0s. Unique request ID: 40 | 2015-02-27 13:18:33 Removed historical data download ID 40 | 2015-02-27 13:18:33 HD Request # 43 | Downloading Historical Daily chart data for EURAUD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:33 HD Request # 43 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:33 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:33 Chart: USDCAD Daily #7 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:33 * Socket (44) | Connected. | 2015-02-27 13:18:33 HD Request # 43 | Sending historical data logon request message. | 2015-02-27 13:18:33 Chart: USDCHF Daily #8 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:33 * HD Request # 43 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:34 HD Request # 43 | Decompressing data. | 2015-02-27 13:18:34 HD Request # 43 | Receiving historical Daily data for EURAUD starting at 2015-02-26 | 2015-02-27 13:18:34 Writing historical Daily data for EURAUD to the file EURAUD.dly | 2015-02-27 13:18:34 Socket (44) | Shutdown and closed. | 2015-02-27 13:18:34 The network socket for historical data has been closed. | 2015-02-27 13:18:34 HD Request # 43 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for EURAUD | 2015-02-27 13:18:34 HD Request # 43 | Daily download COMPLETE for EURAUD. Completion time: 1s. Unique request ID: 41 | 2015-02-27 13:18:34 Removed historical data download ID 41 | 2015-02-27 13:18:34 HD Request # 44 | Downloading Historical Daily chart data for EURCAD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:34 HD Request # 44 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:34 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:34 Socket (45) | Connected. | 2015-02-27 13:18:34 HD Request # 44 | Sending historical data logon request message. | 2015-02-27 13:18:34 HD Request # 44 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:34 HD Request # 44 | Decompressing data. | 2015-02-27 13:18:34 HD Request # 44 | Receiving historical Daily data for EURCAD starting at 2015-02-26 | 2015-02-27 13:18:34 Writing historical Daily data for EURCAD to the file EURCAD.dly | 2015-02-27 13:18:34 Socket (45) | Shutdown and closed. | 2015-02-27 13:18:34 The network socket for historical data has been closed. | 2015-02-27 13:18:34 HD Request # 44 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for EURCAD | 2015-02-27 13:18:34 HD Request # 44 | Daily download COMPLETE for EURCAD. Completion time: 0s. Unique request ID: 42 | 2015-02-27 13:18:34 Removed historical data download ID 42 | 2015-02-27 13:18:34 HD Request # 45 | Downloading Historical Daily chart data for EURGBP. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:34 HD Request # 45 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:34 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:34 Chart: EURJPY Daily #9 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:34 * Socket (46) | Connected. | 2015-02-27 13:18:34 HD Request # 45 | Sending historical data logon request message. | 2015-02-27 13:18:34 Chart: EURAUD Daily #10 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:34 * Chart: EURCAD Daily #11 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:34 * HD Request # 45 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:34 HD Request # 45 | Decompressing data. | 2015-02-27 13:18:34 HD Request # 45 | Receiving historical Daily data for EURGBP starting at 2015-02-26 | 2015-02-27 13:18:34 Writing historical Daily data for EURGBP to the file EURGBP.dly | 2015-02-27 13:18:34 Socket (46) | Shutdown and closed. | 2015-02-27 13:18:34 The network socket for historical data has been closed. | 2015-02-27 13:18:34 HD Request # 45 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for EURGBP | 2015-02-27 13:18:34 HD Request # 45 | Daily download COMPLETE for EURGBP. Completion time: 0s. Unique request ID: 43 | 2015-02-27 13:18:34 Removed historical data download ID 43 | 2015-02-27 13:18:34 HD Request # 46 | Downloading Historical Daily chart data for EURCHF. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:34 HD Request # 46 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:34 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:34 Socket (47) | Connected. | 2015-02-27 13:18:34 HD Request # 46 | Sending historical data logon request message. | 2015-02-27 13:18:34 HD Request # 46 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:34 HD Request # 46 | Decompressing data. | 2015-02-27 13:18:34 HD Request # 46 | Receiving historical Daily data for EURCHF starting at 2015-02-26 | 2015-02-27 13:18:34 Writing historical Daily data for EURCHF to the file EURCHF.dly | 2015-02-27 13:18:34 Socket (47) | Shutdown and closed. | 2015-02-27 13:18:34 The network socket for historical data has been closed. | 2015-02-27 13:18:34 HD Request # 46 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for EURCHF | 2015-02-27 13:18:34 HD Request # 46 | Daily download COMPLETE for EURCHF. Completion time: 0s. Unique request ID: 44 | 2015-02-27 13:18:34 Removed historical data download ID 44 | 2015-02-27 13:18:34 HD Request # 47 | Downloading Historical Daily chart data for GBPJPY. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:34 HD Request # 47 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:34 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:34 Socket (48) | Connected. | 2015-02-27 13:18:34 HD Request # 47 | Sending historical data logon request message. | 2015-02-27 13:18:34 HD Request # 47 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:34 HD Request # 47 | Decompressing data. | 2015-02-27 13:18:34 HD Request # 47 | Receiving historical Daily data for GBPJPY starting at 2015-02-26 | 2015-02-27 13:18:34 Writing historical Daily data for GBPJPY to the file GBPJPY.dly | 2015-02-27 13:18:34 Socket (48) | Shutdown and closed. | 2015-02-27 13:18:34 The network socket for historical data has been closed. | 2015-02-27 13:18:34 HD Request # 47 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for GBPJPY | 2015-02-27 13:18:34 HD Request # 47 | Daily download COMPLETE for GBPJPY. Completion time: 0s. Unique request ID: 45 | 2015-02-27 13:18:34 Removed historical data download ID 45 | 2015-02-27 13:18:34 HD Request # 48 | Downloading Historical Daily chart data for AUDJPY. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:34 HD Request # 48 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:34 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:34 Socket (49) | Connected. | 2015-02-27 13:18:35 HD Request # 48 | Sending historical data logon request message. | 2015-02-27 13:18:35 Chart: EURGBP Daily #12 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:35 * HD Request # 48 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:35 HD Request # 48 | Decompressing data. | 2015-02-27 13:18:35 HD Request # 48 | Receiving historical Daily data for AUDJPY starting at 2015-02-26 | 2015-02-27 13:18:35 Writing historical Daily data for AUDJPY to the file AUDJPY.dly | 2015-02-27 13:18:35 Socket (49) | Shutdown and closed. | 2015-02-27 13:18:35 The network socket for historical data has been closed. | 2015-02-27 13:18:35 Chart: GBPJPY Daily #15 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:35 * HD Request # 48 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for AUDJPY | 2015-02-27 13:18:35 HD Request # 48 | Daily download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 46 | 2015-02-27 13:18:35 Removed historical data download ID 46 | 2015-02-27 13:18:35 HD Request # 49 | Downloading Historical Daily chart data for NZDJPY. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:35 HD Request # 49 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:35 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:35 Chart: EURCHF Daily #13 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:35 * Socket (50) | Connected. | 2015-02-27 13:18:35 HD Request # 49 | Sending historical data logon request message. | 2015-02-27 13:18:35 HD Request # 49 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:35 HD Request # 49 | Decompressing data. | 2015-02-27 13:18:35 HD Request # 49 | Receiving historical Daily data for NZDJPY starting at 2015-02-26 | 2015-02-27 13:18:35 Writing historical Daily data for NZDJPY to the file NZDJPY.dly | 2015-02-27 13:18:35 Socket (50) | Shutdown and closed. | 2015-02-27 13:18:35 The network socket for historical data has been closed. | 2015-02-27 13:18:35 HD Request # 49 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for NZDJPY | 2015-02-27 13:18:35 HD Request # 49 | Daily download COMPLETE for NZDJPY. Completion time: 0s. Unique request ID: 47 | 2015-02-27 13:18:35 Removed historical data download ID 47 | 2015-02-27 13:18:35 HD Request # 50 | Downloading Historical Daily chart data for CADJPY. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:35 HD Request # 50 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:35 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:35 Chart: AUDJPY Daily #16 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:35 * Socket (51) | Connected. | 2015-02-27 13:18:35 HD Request # 50 | Sending historical data logon request message. | 2015-02-27 13:18:35 Chart: NZDJPY Daily #17 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:35 * HD Request # 50 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:35 HD Request # 50 | Decompressing data. | 2015-02-27 13:18:35 HD Request # 50 | Receiving historical Daily data for CADJPY starting at 2015-02-26 | 2015-02-27 13:18:35 Writing historical Daily data for CADJPY to the file CADJPY.dly | 2015-02-27 13:18:35 Socket (51) | Shutdown and closed. | 2015-02-27 13:18:35 The network socket for historical data has been closed. | 2015-02-27 13:18:35 HD Request # 50 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for CADJPY | 2015-02-27 13:18:35 HD Request # 50 | Daily download COMPLETE for CADJPY. Completion time: 0s. Unique request ID: 48 | 2015-02-27 13:18:35 Removed historical data download ID 48 | 2015-02-27 13:18:35 HD Request # 51 | Downloading Historical Daily chart data for GBPAUD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:35 HD Request # 51 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:35 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:35 Socket (52) | Connected. | 2015-02-27 13:18:35 HD Request # 51 | Sending historical data logon request message. | 2015-02-27 13:18:35 Chart: CADJPY Daily #18 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:35 * HD Request # 51 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:35 HD Request # 51 | Decompressing data. | 2015-02-27 13:18:35 HD Request # 51 | Receiving historical Daily data for GBPAUD starting at 2015-02-26 | 2015-02-27 13:18:35 Writing historical Daily data for GBPAUD to the file GBPAUD.dly | 2015-02-27 13:18:35 Socket (52) | Shutdown and closed. | 2015-02-27 13:18:35 The network socket for historical data has been closed. | 2015-02-27 13:18:35 HD Request # 51 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for GBPAUD | 2015-02-27 13:18:35 HD Request # 51 | Daily download COMPLETE for GBPAUD. Completion time: 0s. Unique request ID: 49 | 2015-02-27 13:18:35 Removed historical data download ID 49 | 2015-02-27 13:18:35 HD Request # 52 | Downloading Historical Daily chart data for GBPCAD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:35 HD Request # 52 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:35 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:35 Socket (53) | Connected. | 2015-02-27 13:18:35 HD Request # 52 | Sending historical data logon request message. | 2015-02-27 13:18:35 HD Request # 52 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:35 HD Request # 52 | Decompressing data. | 2015-02-27 13:18:35 HD Request # 52 | Receiving historical Daily data for GBPCAD starting at 2015-02-26 | 2015-02-27 13:18:35 Writing historical Daily data for GBPCAD to the file GBPCAD.dly | 2015-02-27 13:18:35 Socket (53) | Shutdown and closed. | 2015-02-27 13:18:35 The network socket for historical data has been closed. | 2015-02-27 13:18:35 HD Request # 52 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for GBPCAD | 2015-02-27 13:18:35 HD Request # 52 | Daily download COMPLETE for GBPCAD. Completion time: 0s. Unique request ID: 50 | 2015-02-27 13:18:35 Removed historical data download ID 50 | 2015-02-27 13:18:35 HD Request # 53 | Downloading Historical Daily chart data for GBPNZD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:35 HD Request # 53 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:35 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:35 Socket (54) | Connected. | 2015-02-27 13:18:35 HD Request # 53 | Sending historical data logon request message. | 2015-02-27 13:18:35 HD Request # 53 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:35 HD Request # 53 | Decompressing data. | 2015-02-27 13:18:35 HD Request # 53 | Receiving historical Daily data for GBPNZD starting at 2015-02-26 | 2015-02-27 13:18:35 Writing historical Daily data for GBPNZD to the file GBPNZD.dly | 2015-02-27 13:18:35 Socket (54) | Shutdown and closed. | 2015-02-27 13:18:35 The network socket for historical data has been closed. | 2015-02-27 13:18:35 HD Request # 53 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for GBPNZD | 2015-02-27 13:18:35 HD Request # 53 | Daily download COMPLETE for GBPNZD. Completion time: 0s. Unique request ID: 51 | 2015-02-27 13:18:35 Removed historical data download ID 51 | 2015-02-27 13:18:35 HD Request # 54 | Downloading Historical Daily chart data for AUDNZD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:35 HD Request # 54 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:35 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:35 Socket (55) | Connected. | 2015-02-27 13:18:36 HD Request # 54 | Sending historical data logon request message. | 2015-02-27 13:18:36 Chart: GBPAUD Daily #19 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:36 * HD Request # 54 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:36 HD Request # 54 | Decompressing data. | 2015-02-27 13:18:36 HD Request # 54 | Receiving historical Daily data for AUDNZD starting at 2015-02-26 | 2015-02-27 13:18:36 Writing historical Daily data for AUDNZD to the file AUDNZD.dly | 2015-02-27 13:18:36 Socket (55) | Shutdown and closed. | 2015-02-27 13:18:36 The network socket for historical data has been closed. | 2015-02-27 13:18:36 HD Request # 54 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for AUDNZD | 2015-02-27 13:18:36 HD Request # 54 | Daily download COMPLETE for AUDNZD. Completion time: 1s. Unique request ID: 52 | 2015-02-27 13:18:36 Removed historical data download ID 52 | 2015-02-27 13:18:36 HD Request # 55 | Downloading Historical Daily chart data for USDSGD. Starting date: 2015-02-19. Service: fxcm | 2015-02-27 13:18:36 HD Request # 55 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:36 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:36 Socket (56) | Connected. | 2015-02-27 13:18:36 HD Request # 55 | Sending historical data logon request message. | 2015-02-27 13:18:36 Chart: GBPCAD Daily #20 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:36 * HD Request # 55 | Requesting historical Daily data starting at 2015-02-19. | 2015-02-27 13:18:36 HD Request # 55 | Decompressing data. | 2015-02-27 13:18:36 HD Request # 55 | Receiving historical Daily data for USDSGD starting at 2015-02-19 | 2015-02-27 13:18:36 Writing historical Daily data for USDSGD to the file USDSGD.dly | 2015-02-27 13:18:36 Socket (56) | Shutdown and closed. | 2015-02-27 13:18:36 The network socket for historical data has been closed. | 2015-02-27 13:18:36 HD Request # 55 | Received 2 records from 2015-02-19 00:00:00 to 2015-02-20 00:00:00 (2.0 days) and wrote 2 records for USDSGD | 2015-02-27 13:18:36 HD Request # 55 | Daily download COMPLETE for USDSGD. Completion time: 0s. Unique request ID: 53 | 2015-02-27 13:18:36 Removed historical data download ID 53 | 2015-02-27 13:18:36 HD Request # 56 | Downloading Historical Daily chart data for USDHKD. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:36 HD Request # 56 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:36 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:36 Chart: AUDNZD Daily #22 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:36 * Socket (57) | Connected. | 2015-02-27 13:18:36 HD Request # 56 | Sending historical data logon request message. | 2015-02-27 13:18:36 Chart: GBPNZD Daily #21 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:36 * HD Request # 56 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:36 HD Request # 56 | Decompressing data. | 2015-02-27 13:18:36 HD Request # 56 | Receiving historical Daily data for USDHKD starting at 2015-02-26 | 2015-02-27 13:18:36 Writing historical Daily data for USDHKD to the file USDHKD.dly | 2015-02-27 13:18:36 Socket (57) | Shutdown and closed. | 2015-02-27 13:18:36 The network socket for historical data has been closed. | 2015-02-27 13:18:36 HD Request # 56 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for USDHKD | 2015-02-27 13:18:36 HD Request # 56 | Daily download COMPLETE for USDHKD. Completion time: 0s. Unique request ID: 54 | 2015-02-27 13:18:36 Removed historical data download ID 54 | 2015-02-27 13:18:36 HD Request # 57 | Downloading Historical Daily chart data for USDMXN. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:36 HD Request # 57 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:36 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:36 Socket (58) | Connected. | 2015-02-27 13:18:36 HD Request # 57 | Sending historical data logon request message. | 2015-02-27 13:18:36 HD Request # 57 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:36 Chart: USDSGD Daily #23 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:36 * HD Request # 57 | Decompressing data. | 2015-02-27 13:18:36 HD Request # 57 | Receiving historical Daily data for USDMXN starting at 2015-02-26 | 2015-02-27 13:18:36 Writing historical Daily data for USDMXN to the file USDMXN.dly | 2015-02-27 13:18:36 Socket (58) | Shutdown and closed. | 2015-02-27 13:18:36 The network socket for historical data has been closed. | 2015-02-27 13:18:36 HD Request # 57 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for USDMXN | 2015-02-27 13:18:36 HD Request # 57 | Daily download COMPLETE for USDMXN. Completion time: 0s. Unique request ID: 55 | 2015-02-27 13:18:36 Removed historical data download ID 55 | 2015-02-27 13:18:36 HD Request # 58 | Downloading Historical Daily chart data for USDCNH. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:36 HD Request # 58 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:36 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:36 Socket (59) | Connected. | 2015-02-27 13:18:36 HD Request # 58 | Sending historical data logon request message. | 2015-02-27 13:18:36 HD Request # 58 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:36 HD Request # 58 | Decompressing data. | 2015-02-27 13:18:36 HD Request # 58 | Receiving historical Daily data for USDCNH starting at 2015-02-26 | 2015-02-27 13:18:36 Writing historical Daily data for USDCNH to the file USDCNH.dly | 2015-02-27 13:18:36 Socket (59) | Shutdown and closed. | 2015-02-27 13:18:36 The network socket for historical data has been closed. | 2015-02-27 13:18:36 HD Request # 58 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for USDCNH | 2015-02-27 13:18:36 HD Request # 58 | Daily download COMPLETE for USDCNH. Completion time: 0s. Unique request ID: 56 | 2015-02-27 13:18:36 Removed historical data download ID 56 | 2015-02-27 13:18:36 HD Request # 59 | Downloading Historical Daily chart data for USDTRY. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:36 HD Request # 59 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:36 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:36 Socket (60) | Connected. | 2015-02-27 13:18:36 HD Request # 59 | Sending historical data logon request message. | 2015-02-27 13:18:36 Chart: USDMXN Daily #26 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:36 * Chart: USDCNH Daily #25 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:36 * HD Request # 59 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:36 Chart: USDHKD Daily #24 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:36 * HD Request # 59 | Decompressing data. | 2015-02-27 13:18:36 HD Request # 59 | Receiving historical Daily data for USDTRY starting at 2015-02-26 | 2015-02-27 13:18:36 Writing historical Daily data for USDTRY to the file USDTRY.dly | 2015-02-27 13:18:36 Socket (60) | Shutdown and closed. | 2015-02-27 13:18:36 The network socket for historical data has been closed. | 2015-02-27 13:18:36 HD Request # 59 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for USDTRY | 2015-02-27 13:18:37 HD Request # 59 | Daily download COMPLETE for USDTRY. Completion time: 1s. Unique request ID: 57 | 2015-02-27 13:18:37 Removed historical data download ID 57 | 2015-02-27 13:18:37 HD Request # 60 | Downloading Historical Daily chart data for USDZAR. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:37 HD Request # 60 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:37 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:37 Socket (61) | Connected. | 2015-02-27 13:18:37 HD Request # 60 | Sending historical data logon request message. | 2015-02-27 13:18:37 HD Request # 60 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:37 HD Request # 60 | Decompressing data. | 2015-02-27 13:18:37 HD Request # 60 | Receiving historical Daily data for USDZAR starting at 2015-02-26 | 2015-02-27 13:18:37 Writing historical Daily data for USDZAR to the file USDZAR.dly | 2015-02-27 13:18:37 Socket (61) | Shutdown and closed. | 2015-02-27 13:18:37 The network socket for historical data has been closed. | 2015-02-27 13:18:37 HD Request # 60 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for USDZAR | 2015-02-27 13:18:37 HD Request # 60 | Daily download COMPLETE for USDZAR. Completion time: 0s. Unique request ID: 58 | 2015-02-27 13:18:37 Removed historical data download ID 58 | 2015-02-27 13:18:37 HD Request # 61 | Downloading Historical Daily chart data for EURCZK. Starting date: 2015-01-29. Service: fxcm | 2015-02-27 13:18:37 HD Request # 61 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:37 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:37 Socket (62) | Connected. | 2015-02-27 13:18:37 HD Request # 61 | Sending historical data logon request message. | 2015-02-27 13:18:37 HD Request # 61 | Requesting historical Daily data starting at 2015-01-29. | 2015-02-27 13:18:37 HD Request # 61 | Decompressing data. | 2015-02-27 13:18:37 HD Request # 61 | Receiving historical Daily data for EURCZK starting at 2015-01-29 | 2015-02-27 13:18:37 Writing historical Daily data for EURCZK to the file EURCZK.dly | 2015-02-27 13:18:37 Socket (62) | Shutdown and closed. | 2015-02-27 13:18:37 The network socket for historical data has been closed. | 2015-02-27 13:18:37 HD Request # 61 | Received 2 records from 2015-01-29 00:00:00 to 2015-01-30 00:00:00 (2.0 days) and wrote 2 records for EURCZK | 2015-02-27 13:18:37 HD Request # 61 | Daily download COMPLETE for EURCZK. Completion time: 0s. Unique request ID: 59 | 2015-02-27 13:18:37 Removed historical data download ID 59 | 2015-02-27 13:18:37 HD Request # 62 | Downloading Historical Daily chart data for EURTRY. Starting date: 2015-02-26. Service: fxcm | 2015-02-27 13:18:37 HD Request # 62 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:37 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:37 Socket (63) | Connected. | 2015-02-27 13:18:37 HD Request # 62 | Sending historical data logon request message. | 2015-02-27 13:18:37 HD Request # 62 | Requesting historical Daily data starting at 2015-02-26. | 2015-02-27 13:18:37 Chart: USDTRY Daily #27 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:37 * Chart: USDZAR Daily #28 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:37 * HD Request # 62 | Decompressing data. | 2015-02-27 13:18:37 HD Request # 62 | Receiving historical Daily data for EURTRY starting at 2015-02-26 | 2015-02-27 13:18:37 Writing historical Daily data for EURTRY to the file EURTRY.dly | 2015-02-27 13:18:37 Socket (63) | Shutdown and closed. | 2015-02-27 13:18:37 The network socket for historical data has been closed. | 2015-02-27 13:18:37 HD Request # 62 | Received 2 records from 2015-02-26 00:00:00 to 2015-02-27 00:00:00 (2.0 days) and wrote 2 records for EURTRY | 2015-02-27 13:18:37 HD Request # 62 | Daily download COMPLETE for EURTRY. Completion time: 0s. Unique request ID: 60 | 2015-02-27 13:18:37 Removed historical data download ID 60 | 2015-02-27 13:18:37 HD Request # 63 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2015-02-27 13:18:37 HD Request # 63 | Download start Date-Time: 2015-02-27 11:09:47.0 | 2015-02-27 13:18:37 HD Request # 63 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:37 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:37 Chart: EURCZK Daily #29 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:37 * Socket (64) | Connected. | 2015-02-27 13:18:37 HD Request # 63 | Sending historical data logon request message. | 2015-02-27 13:18:37 HD Request # 63 | Requesting Intraday data. Start Date-Time: 2015-02-27 11:09:47. Record interval: 1. Symbol: XAUUSD | 2015-02-27 13:18:37 HD Request # 63 | Decompressing data. | 2015-02-27 13:18:37 HD Request # 63 | Receiving Intraday data for XAUUSD starting at 2015-02-27 11:09:47 | 2015-02-27 13:18:37 HD Request # 63 | Timestamp of first Intraday data file record written: 2015-02-27 11:09:47 | 2015-02-27 13:18:37 Chart: EURTRY Daily #30 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:37 * Socket (64) | Shutdown and closed. | 2015-02-27 13:18:37 The network socket for historical data has been closed. | 2015-02-27 13:18:37 HD Request # 63 | Received 3941 records from 2015-02-27 11:09:47 to 2015-02-27 13:18:30 (2.1 hours) and wrote 3941 records for XAUUSD | 2015-02-27 13:18:37 HD Request # 63 | Intraday download COMPLETE for XAUUSD. Completion time: 0s. Unique request ID: 61 | 2015-02-27 13:18:37 Removed historical data download ID 61 | 2015-02-27 13:18:37 Real-time Intraday chart data file updates started for XAUUSD | 2015-02-27 13:18:37 HD Request # 64 | Downloading Intraday chart data for USDOLLAR to the file USDOLLAR.scid. Service: fxcm | 2015-02-27 13:18:37 HD Request # 64 | Download start Date-Time: 2015-02-27 13:17:59.0 | 2015-02-27 13:18:37 HD Request # 64 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:37 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:37 Socket (65) | Connected. | 2015-02-27 13:18:37 HD Request # 64 | Sending historical data logon request message. | 2015-02-27 13:18:37 HD Request # 64 | Requesting Intraday data. Start Date-Time: 2015-02-27 13:17:59. Record interval: 1. Symbol: USDOLLAR | 2015-02-27 13:18:37 HD Request # 64 | Decompressing data. | 2015-02-27 13:18:38 HD Request # 64 | Receiving Intraday data for USDOLLAR starting at 2015-02-27 13:17:59 | 2015-02-27 13:18:38 HD Request # 64 | Timestamp of first Intraday data file record written: 2015-02-27 13:17:59 | 2015-02-27 13:18:38 Socket (65) | Shutdown and closed. | 2015-02-27 13:18:38 The network socket for historical data has been closed. | 2015-02-27 13:18:38 HD Request # 64 | Received 3 records from 2015-02-27 13:17:59 to 2015-02-27 13:18:24 (25.0 seconds) and wrote 3 records for USDOLLAR | 2015-02-27 13:18:38 HD Request # 64 | Intraday download COMPLETE for USDOLLAR. Completion time: 0s. Unique request ID: 75 | 2015-02-27 13:18:38 Removed historical data download ID 75 | 2015-02-27 13:18:38 Real-time Intraday chart data file updates started for USDOLLAR | 2015-02-27 13:18:38 HD Request # 65 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2015-02-27 13:18:38 HD Request # 65 | Download start Date-Time: 2015-02-27 13:18:16.0 | 2015-02-27 13:18:38 HD Request # 65 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:38 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:38 Socket (66) | Connected. | 2015-02-27 13:18:38 HD Request # 65 | Sending historical data logon request message. | 2015-02-27 13:18:38 HD Request # 65 | Requesting Intraday data. Start Date-Time: 2015-02-27 13:18:16. Record interval: 1. Symbol: EURUSD | 2015-02-27 13:18:38 HD Request # 65 | Decompressing data. | 2015-02-27 13:18:38 HD Request # 65 | Receiving Intraday data for EURUSD starting at 2015-02-27 13:18:16 | 2015-02-27 13:18:38 HD Request # 65 | Timestamp of first Intraday data file record written: 2015-02-27 13:18:16 | 2015-02-27 13:18:38 Socket (66) | Shutdown and closed. | 2015-02-27 13:18:38 The network socket for historical data has been closed. | 2015-02-27 13:18:38 HD Request # 65 | Received 9 records from 2015-02-27 13:18:16 to 2015-02-27 13:18:29 (13.0 seconds) and wrote 9 records for EURUSD | 2015-02-27 13:18:38 Added 1 Time and Sales records to Intraday data file for EURUSD after download. | 2015-02-27 13:18:38 HD Request # 65 | Intraday download COMPLETE for EURUSD. Completion time: 0s. Unique request ID: 85 | 2015-02-27 13:18:38 Removed historical data download ID 85 | 2015-02-27 13:18:38 Real-time Intraday chart data file updates started for EURUSD | 2015-02-27 13:18:38 HD Request # 66 | Downloading Intraday chart data for USDCHF to the file USDCHF.scid. Service: fxcm | 2015-02-27 13:18:38 HD Request # 66 | Download start Date-Time: 2015-02-27 13:18:18.0 | 2015-02-27 13:18:38 HD Request # 66 | Using server: ds4.sierracharts.com port 10149 | 2015-02-27 13:18:38 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-02-27 13:18:38 Socket (67) | Connected. | 2015-02-27 13:18:38 HD Request # 66 | Sending historical data logon request message. | 2015-02-27 13:18:38 HD Request # 66 | Requesting Intraday data. Start Date-Time: 2015-02-27 13:18:18. Record interval: 1. Symbol: USDCHF | 2015-02-27 13:18:38 HD Request # 66 | Decompressing data. | 2015-02-27 13:18:38 HD Request # 66 | Receiving Intraday data for USDCHF starting at 2015-02-27 13:18:18 | 2015-02-27 13:18:38 HD Request # 66 | Timestamp of first Intraday data file record written: 2015-02-27 13:18:18 | 2015-02-27 13:18:38 Socket (67) | Shutdown and closed. | 2015-02-27 13:18:38 The network socket for historical data has been closed. | 2015-02-27 13:18:38 HD Request # 66 | Received 8 records from 2015-02-27 13:18:18 to 2015-02-27 13:18:36 (18.0 seconds) and wrote 8 records for USDCHF | 2015-02-27 13:18:38 HD Request # 66 | Intraday download COMPLETE for USDCHF. Completion time: 0s. Unique request ID: 86 | 2015-02-27 13:18:38 Removed historical data download ID 86 | 2015-02-27 13:18:38 Real-time Intraday chart data file updates started for USDCHF | 2015-02-27 13:18:38 HD Request # 67 | Downloading Intraday chart data for USDJPY to the file USDJPY.scid. Service: fxcm | 2015-02-27 13:18:38 HD Request # 67 | Download start Date-Time: 2015-02-27 13:18:21.0 | 2015-02-27 13:18:38 HD Request # 67 | Using server: ds5.sierracharts.com port 10149 | 2015-02-27 13:18:38 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-27 13:18:38 Socket (68) | Connected. | 2015-02-27 13:18:38 HD Request # 67 | Sending historical data logon request message. | 2015-02-27 13:18:38 HD Request # 67 | Requesting Intraday data. Start Date-Time: 2015-02-27 13:18:21. Record interval: 1. Symbol: USDJPY | 2015-02-27 13:18:38 HD Request # 67 | Decompressing data. | 2015-02-27 13:18:38 HD Request # 67 | Receiving Intraday data for USDJPY starting at 2015-02-27 13:18:21 | 2015-02-27 13:18:38 HD Request # 67 | Timestamp of first Intraday data file record written: 2015-02-27 13:18:21 | 2015-02-27 13:18:38 Socket (68) | Shutdown and closed. | 2015-02-27 13:18:38 The network socket for historical data has been closed. | 2015-02-27 13:18:38 HD Request # 67 | Received 5 records from 2015-02-27 13:18:21 to 2015-02-27 13:18:37 (16.0 seconds) and wrote 5 records for USDJPY | 2015-02-27 13:18:38 HD Request # 67 | Intraday download COMPLETE for USDJPY. Completion time: 0s. Unique request ID: 87 | 2015-02-27 13:18:38 Removed historical data download ID 87 | 2015-02-27 13:18:38 Real-time Intraday chart data file updates started for USDJPY | 2015-02-27 13:18:38 HD Request # 68 | Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: fxcm | 2015-02-27 13:18:38 HD Request # 68 | Download start Date-Time: 2015-02-27 13:18:21.0 | 2015-02-27 13:18:38 HD Request # 68 | Using server: ds3.sierracharts.com port 10149 | 2015-02-27 13:18:38 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-27 13:18:38 Socket (69) | Connected. | 2015-02-27 13:18:38 HD Request # 68 | Sending historical data logon request message. | 2015-02-27 13:18:38 HD Request # 68 | Requesting Intraday data. Start Date-Time: 2015-02-27 13:18:21. Record interval: 1. Symbol: USDCAD | 2015-02-27 13:18:38 HD Request # 68 | Decompressing data. | 2015-02-27 13:18:38 HD Request # 68 | Receiving Intraday data for USDCAD starting at 2015-02-27 13:18:21 | 2015-02-27 13:18:38 HD Request # 68 | Timestamp of first Intraday data file record written: 2015-02-27 13:18:21 | 2015-02-27 13:18:38 Socket (69) | Shutdown and closed. | 2015-02-27 13:18:38 The network socket for historical data has been closed. | 2015-02-27 13:18:38 HD Request # 68 | Received 4 records from 2015-02-27 13:18:21 to 2015-02-27 13:18:39 (18.0 seconds) and wrote 4 records for USDCAD | 2015-02-27 13:18:38 HD Request # 68 | Intraday download COMPLETE for USDCAD. Completion time: 0s. Unique request ID: 88 | 2015-02-27 13:18:38 Removed historical data download ID 88 | 2015-02-27 13:18:38 Real-time Intraday chart data file updates started for USDCAD | 2015-02-27 13:18:38 Chart: USDZAR Daily #28 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:40 * Chart: EURCHF Daily #13 | Study: CandleStick Patterns Finder | You need to be on a software service package that includes Additional Features to use this study. | 2015-02-27 13:18:51 * |
[2015-02-27 22:31:28] |
Perform a Full Reset of the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-02 16:25:55] |
BBFX1966 - Posts: 18 |
Unfortunately that did not work...do I have the right package, I use P#1
[2015-03-02 16:36:06] |
OK, we apologize for this. We should have recognized this. Usually the service package is not the problem but in this case it is. You do need Sierra Chart Service Package 3 or 5. You actually figured out the problem faster than we did. To change your Sierra Chart service package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on "Change Service Package". The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your usage time is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-02 16:36:26
[2015-03-02 16:45:40] |
Lucky guess on my part haha. Ok i will adjust the package Thanks again |
