Date/Time: Sat, 21 Dec 2024 18:38:39 +0000
Cahnge the Symbol in All charts in a ChartBook
View Count: 1021
[2015-02-18 02:40:31] |
User121729 - Posts: 37 |
I want to be able to change the symbol in all of the charts in a chartbook at one time to the same symbol versus having to change each each individual chart. How do I do that? Thanks |
[2015-02-18 04:21:18] |
joshtrader - Posts: 492 |
chart linking http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LinkNumber |
[2015-02-26 08:55:25] |
This can be done by using the Chart Linking feature which is documented here: http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChartLinking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
