Date/Time: Sat, 21 Dec 2024 18:23:43 +0000
Replay problems and Data export
View Count: 1022
[2015-01-28 18:27:24] |
User98044 - Posts: 4 |
I downloaded the historical data (CFDs) then I go to replay, (it's in trade simulation mode) and all I get is this message even after I have cleared. I checked its not in daily timeframe. CLEAR REPLAY DATA (trade activity...) IN ACCOUNT SIM1 Also how do I export 1m data (not tick data) for FXCM symbols |
[2015-01-28 18:30:26] |
That message is normal. Follow the instructions here to replay a chart: https://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#BasicInstructions Refer to this page to export data: https://www.sierrachart.com/index.php?page=doc/doc_ImportExport.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-28 20:36:00] |
I tried exporting the data like it said it should be 1 minute data but it is tick data 2014/5/6, 18:59:57.0, 9452.5, 9452.5, 9452.5, 9452.5, 1, 1, 1, 0 2014/5/6, 19:00:00.0, 9451.5, 9451.5, 9451.5, 9451.5, 1, 1, 1, 0 |
[2015-01-29 07:17:31] |
If you want to export 1 minute data, use the Write Bar Data to File study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s182 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-29 16:23:08] |
Thanks, I managed it How far does the data go back for FXCM GER30 and US30, it's barely 6 months, even 1m data is that the furthest it goes back? |
[2015-01-29 17:50:49] |
There is more data available. Refer to this section here: http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-26 21:29:07] |
I want a 77 tick chart for FXCM CFD symbols, is this available? Also can I choose a specific date to replay chart or do I have to scroll all the way through the chart(which isn't really possible because there are no dates and it would take forever on the 1 min chart) thanks |
[2015-02-27 22:38:09] |
1. Yes. Use the Bar Period Type >> Number of Trades Per Bar setting: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar 2. You can set the chart to display a specific date range. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LastDatetoDisplay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
