Date/Time: Sat, 23 Nov 2024 07:30:47 +0000
Show Order Fills
View Count: 1953
[2013-05-17 15:02:35]
User59482 - Posts: 14
The Show Order Fills arrows are not showing at the correct moment of the fill. The entry and exit time is correct but the arrow is being placed on the chart at not the correct moment of the fill. For example, on a 1 minute chart the entry shows on the bar where the fill took place, but when I go to a 5 second chart of that fill, the arrow is sitting back several bars in empty space, not showing where and on which specific 5 second bar that the fill took place. If the chart prices are moving up and down through that price, I am unable to see exactly where and what bar the fill took place. It should show the correct bar even on a tick chart. How do I set it to show the arrow at the correct time (moment), no matter what time frame the chart is on?
Thank-you
[2013-06-25 18:12:11]
blknsxy - Posts: 29
Were you able to get an answer to this? I wish to chart the Market Depth percentage on a chart, in real time as it is happening. I want to know if it's possible to do?
[2013-06-25 18:29:08]
Futures Operator - Posts: 239
I have the same question, can the show order fill be fixed to actually show the correct time/price of where the order was filled on the chart?
[2013-06-25 21:05:57]
We see no reason why there would be a problem with this as long as your computer's clock is set accurately.
[2013-06-26 19:59:40]
1. If there is a problem with an order fill not displaying at the correct time on the chart, then provide the order fill text from the Trade >> Trade Activity Log >> Trade Activity and an image of the chart showing where the order fill is displayed.
To provide an image of the chart, please follow these instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
2.
Use the Draw DOM Graph on Chart feature:
https://www.sierrachart.com/index.php?l=doc/doc_TradeMenu.html#DrawDOMGraph
Date Time Of Last Edit: 2013-06-26 20:06:26
