Date/Time: Sat, 21 Dec 2024 18:29:47 +0000
Numbers Bars: Zero Entries?
View Count: 1089
[2014-11-21 21:19:22] |
User93103 - Posts: 48 |
Hello: Every morning when the Chartbook is lunched for trading, there are Zeros in two or three columns of the Numbers Bars (Range Bar) for the Symbols (NQ, CL, GC …) that are on my list? Is it the data feed (Rithmic) that I have recently switched to, or ....!? God Bless Thank you Ben |
[2014-11-22 05:14:51] |
This is a limitation with the Rithmic data feed. You need to use the Sierra Chart Real-time and Historical Exchange Data Feed to solve this problem: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
