Date/Time: Sat, 21 Dec 2024 18:21:42 +0000
Window edit
View Count: 1056
[2014-11-19 17:45:49] |
julian pineda - Posts: 60 |
there is a psobilitity to lock a window? to stay on top ? |
[2014-11-19 20:36:08] |
Only if it is detached: https://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-19 20:56:34] |
perfect, thanks. can i remove thos levels? just the little window with the numbers and without the margins? |
2014-11-19_1552.png / V - Attached On 2014-11-19 20:56:09 UTC - Size: 30.45 KB - 348 views |
[2014-11-21 06:04:11] |
You can remove the menu and the Time and Values Scales. The settings for these are documented. Follow these website links from the top of this page: Documentation >> Table of Contents >> Chart Menu / Chart Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-21 06:05:47
