Date/Time: Sat, 21 Dec 2024 18:35:53 +0000
Custom color #1 to #8
View Count: 1684
[2014-10-30 16:15:50]
User15952 - Posts: 132
I have looked everywhere to change the colors in the menu.
Please could someone point me to where it is done.
[2014-10-30 18:50:43]
Another question, is it possible to have more than 8 TC (Config)?
[2014-10-31 07:00:56]
Here is the documentation for changing the colors of Chart Drawings:
https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#QuicklyChangingColors
There is a maximum of 8 tool configurations.
[2015-07-16 08:32:17]
Acro - Posts: 441
With the top 8 colors, is there any way to change colors 2 to 8 in the top row other than by pressing the same color again and again, in which case it will change the bottom row too ?
If eg you want to change top row color 3, I can't see a way to do it without also changing top row color 1, bottom row color 1, top row color 2 and bottom row color 2
[2015-07-16 09:52:38]
You first need to click on the color box in the Custom Color section on the left before pressing the Add To Custom Colors button over on the right side.
Date Time Of Last Edit: 2015-07-16 11:07:05
[2015-07-16 11:43:41]
Acro - Posts: 441
Resolved - don't worry
Date Time Of Last Edit: 2015-07-16 12:03:35
imageScreenshot 2015-07-16 19.42.14.jpg / V - Attached On 2015-07-16 11:42:41 UTC - Size: 58.8 KB - 440 views
[2015-07-16 15:06:04]
Marek F - Posts: 244
+1
[2015-07-16 15:24:56]
+1
