Date/Time: Sat, 18 May 2024 07:57:51 +0000
Limit Bid Ask DOM
View Count: 86
[2024-05-04 09:14:44] |
Tin43 - Posts: 78 |
I got a DOM configuration. I can see Bid Ask market orders but I can't see limit orders in their respective columns. Maybe I have to update my SC package? When price trade up or down i can see the markets orders, but limits orders on both sides, only shows a 1, either on the bid or the ask. thanks in advance! |
[2024-05-05 15:32:33] |
You do not need to change you package. You are on the "Base Advanced" package, which gives you access to the real-time data for FOREX, CFD, Crypto Currency and Market Statistics, as well as the Delayed Streaming data for the CME Group, EUREX, CFE, and U.S. Equities. The issue is most likely about the particular symbol you are viewing. There is no market depth data for FOREX, CFD, or U.S. Equities, and some crypto currencies have the market depth and some do not. What is the symbol of your chart? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-05 16:41:23] |
Tin43 - Posts: 78 |
That's the problem... It's the E mini SP500. Maybe it's because i'm replaying it? I'm in replay mode? |
[2024-05-05 22:03:31] |
Tin43 - Posts: 78 |
As you can see in the image... https://www.sierrachart.com/image.php?Image=1714946479354.png I set the Dom to Continuos future Contract. 120 days to load. New york session times. |
[2024-05-06 14:08:23] |
Refer to the following regarding replaying Market Depth data: Replaying Charts: Replaying of Market Depth Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
