Date/Time: Sat, 18 May 2024 06:01:42 +0000
orderflow video | scail setting
View Count: 73
[2024-05-04 07:29:24] |
es10pt - Posts: 5 |
I'm curious about the scale and other settings used in the attached video. When the footprint is positioned inside the screen, the camera is locked and the the camera tracks it as it leaves the extremes of the screen |
[2024-05-05 15:28:44] |
What you are seeing is the way the scale will function in most settings. The only setting where this would not be true is if you have set the scale to "User Defined". Refer to the following: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
