Date/Time: Sat, 18 May 2024 06:01:40 +0000
Denali data delay in Thailand and solution
View Count: 289
[2024-05-04 06:55:43] |
bodzhar - Posts: 15 |
This week around US market open then 2-3 hours into the morning, my real time Denali data for both US futures and equities was running between 15-120 seconds delayed with glitchy erratic updates to charts and time and sales window, this happened till 12-1pm when the problem would cease. I'm in Thailand. I have a 100mbps connection on which everything else was fine, SC is set as an exception for my security software but I am part of a trading group where colleagues in US using SC were not experiencing the issues I was. I usually never use a VPN when trading but decided to try setting mine to a US server and this solved the problem immediately. |
[2024-05-04 11:08:51] |
Sierra_Chart Engineering - Posts: 14423 |
This is the second report we have like this of users having connectivity issues, in Thailand. We will be looking into it and see how to resolve it from our side. Rather than using the VPS what we want you to do is to update Sierra Chart to the current version: Software Download: Fast Update And then set Global Settings >> Sierra Chart Server Settings >> General >> CME Exchange Data Feed Server Address and Port Override to: DS13.SierraCharts.com. You also need to reconnect after this change with File >> Reconnect. Let us know if that resolves the issue. We are also contacting our ISP, Cogent regarding the issue. And we are in the process of adding another ISP but that is not likely to be complete for about four weeks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-04 15:54:34
[2024-05-06 13:10:04] |
Let us know if you are still having the problem when not using the VPN, and if so we need to know your ISP.
[2024-05-07 13:38:03] |
Hello, I updated from SC 2629 to 2634 and set the port override as suggested but data running 15-30 seconds behind this morning. Once again VPN set to USA solved the problem. MY ISP is AIS Thailand
Date Time Of Last Edit: 2024-05-07 14:14:38
[2024-05-07 14:09:51] |
Let us know your ISP. Cogent (Our ISP) asked for this.
[2024-05-07 14:15:08] |
AIS Thailand
[2024-05-07 21:59:11] |
User150671 - Posts: 50 |
Related question: Are you guys planning on expanding Replication of CME Server Data to other locations? e.g. London/Europe? I would be very interested in testing this if you are. |
[2024-05-08 13:42:21] |
FWIW. Data feed fine this morning
[2024-05-08 14:35:22] |
No plans for this for CME: Are you guys planning on expanding Replication of CME Server Data to other locations? e.g. London/Europe? There are very significant infrastructure upgrades we are doing in Europe, but only for EUREX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-08 14:35:42
