Date/Time: Sat, 18 May 2024 07:13:36 +0000
Replay mode clock
View Count: 66
[2024-05-04 02:07:16] |
User423634 - Posts: 21 |
Hello, My question is if I have a quote board built out of different Commodities such as HG, GC, CL, NG, and ES. When using replay mode is there a way for me to start the clock across all those markets at the same time? Or would I have to manually change the market and start the clock a couple seconds afterwards? |
[2024-05-05 15:19:01] |
We are not understanding what you are referring to in terms of "Start the Clock" or how this relates to the Quote Board. The Quote Board can not be replayed. It is not specifically associated with a chart, except for linking to change the symbol. If you are wanting to replay multiple charts at the same time, then there are options for replaying "All Charts in Chartbook" or "Charts with Same Link Number". Refer to the following: Replaying Charts: Charts to Replay Also refer to the following in terms of ensuring that the charts are synchronized during a replay: Replaying Charts: Preventing Loss of Synchronization Between Different Charts During Replay For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
