Date/Time: Sat, 18 May 2024 07:25:07 +0000
Extended POC line on Volume Profile is thicker than the non extended part
View Count: 101
[2024-05-03 10:46:38] |
mojsterr - Posts: 25 |
I have a Volume profile with all the lines set to Width = 1. I have set the lines to extend until future intersection and they all do normally, except the red POC line somehow changes to Width = 2 on the extension, and I can't find a setting to make it thinner. I went through all the settings and I can't fix this. Included picture: https://www.sierrachart.com/image.php?Image=171473289755.png See how the extended red line just gets thicker and stands out the moment it extends out from the Volume Profile Thank you Date Time Of Last Edit: 2024-05-03 13:08:32
[2024-05-03 14:43:53] |
It is very hard for us to tell if the line is thicker than the others. keep in mind that the way the colors are can influence the way these things appear. Make sure the Subgraph for "Point of Control (SG2)" is set to a Width of "1". If this is set to 1, then the extension line should have a width of 1. If you change it to 2, and select Apply, can you see a change occur? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-03 22:02:39] |
I have managed to figure it out. I had the SG2 on "Ignore", but the extension was still visible, so that was messing with me and I couldn't uderstand it. I thought there is some other option somewhere to change. I then figured out I had to change it to "Line", and then change the width. But it is still visible if I have it either on "Ignore" or "Line" anyway. Well, at least the width is ok now. Thank you. Edit: Also, I think the color change is because the line is hidden behind the volume profile, which is grey, but when it comes out of it, the color is brighter. That's why I saw two different shades of red and saw it as thicker. It was just brighter. Date Time Of Last Edit: 2024-05-03 22:05:32
