Date/Time: Sat, 18 May 2024 06:22:18 +0000
[Sticky] [Locked] - Required Update to Current Version of Sierra Chart for Rithmic Users
View Count: 689
[2024-03-19 13:55:28] |
Sierra_Chart Engineering - Posts: 14423 |
We will be requiring an update of Sierra Chart to the current version for users using Sierra Chart with Rithmic, on April 7, to the current version at the time. There are too many users running an older version and it is creating an unnecessary support burden. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-19 14:34:15
[2024-03-19 14:34:23] |
We changed the update date to April 7. We will allow more time as needed for users to update if necessary.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-20 00:26:44
