Date/Time: Sat, 18 May 2024 03:52:02 +0000
[Sticky] [Locked] - Resolution of Poor Network IO Performance under Linux/Wine
View Count: 3777
[2023-07-27 10:08:35] |
Sierra_Chart Engineering - Posts: 14423 |
Prerelease version 2527 has an option to solve the poor network I/O performance under Linux/Wine/Crossover, since version 2524. This also solves the problem of corrupted data received from the network when using Linux/Wine/Crossover. This corrupted data causes zlib errors during historical data downloading and failed data downloads. Update instructions: Software Download: Fast Update After the update set Global Settings >> Sierra Chart Server Settings >> General >> Special >> Use Single Network Receive Buffer for Linux Compatibility to Yes. After that select File >> Disconnect Cancel downloads with Edit >> Cancel All Downloads Connect to the data feed with File >> Connect to Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-05 13:08:17
