Date/Time: Sat, 23 Nov 2024 17:44:07 +0000
long term request: make SC as python/pandas compatible
View Count: 3633
[2014-07-06 06:17:40]
ganz - Posts: 1048
Hello SC Support
The fact is SC Team got rid of an API and it looks like the good thing.
but SC is not covered the huge financial market areas as stocks and options
the proper analysis for thousands of tickers is not a visual analysis but an array/table, statistics, math one
another issue: the statistics and math analysis is not available as it should be using R/matlab and so on
the main problems for a retail trader are to connect to a data source, store the data in a proper way and send an order to a trading service - so this is the area for professional programmers / SC Team /
The suggestion is to make SC as python/pandas compatible in order to use the full advantages of a huge array manipulations with a light speed: easy, fast and open source.
I mean:
1) Add a form/interface to store rt/historical data using the HDF5 file format.
A form should allow a user to choose what tickers will be stored using a choosen data structure
AAPL DateTime Price BidVol AskVol
2) Develop a python module in order to interact a python script to SC
import sierrachart as sc
The module will parse for sc.* in terms of ACSIL or something similar to
int sc.BuyOrder (s_SCNewOrder& NewOrder)
it will be related to trading tasks only
So in this case SC will solve the complex task, imho
some links:
http://pandas.pydata.org/pandas-docs/stable/10min.html
Python for Sierra Chart | Post: 37306
http://pandas.pydata.org/pandas-docs/stable/timeseries.html
http://pandas.pydata.org/pandas-docs/stable/io.html#io-hdf5
thnx
Date Time Of Last Edit: 2014-07-06 06:18:43
