Date/Time: Sat, 18 May 2024 05:24:35 +0000
[Sticky] - Move from Tradeovate/CQG to Teton and Save and Get Better Quality Service!
View Count: 12691
[2023-06-13 14:48:25] |
The Teton Order Routing Service is available through AMP now.
[2023-06-13 16:29:01] |
User772499 - Posts: 48 |
Ok, is it worth switching to? Are there cost savings and data improvements? And who do I make the change with, Amp or SC? Thanks! |
[2023-06-13 17:09:21] |
The cost savings are that you do not pay for any order routing fees, which typically run $0.10 per side. The data is the same as you are using now, as you are using our Denali Exchange Data Feed already. To make the change, you need to start with AMP and ask them to make the change for you. Once they have it setup, then you will follow the instructions at the following link to setup your Sierra Chart to your AMP account: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-13 19:05:46] |
Great. Thank you!
