Date/Time: Tue, 26 Nov 2024 13:34:53 +0000
Relative Volume
View Count: 2105
[2014-04-11 21:31:29] |
User32803 - Posts: 18 |
Does Sierra Chart have a relative volume study or an equivalent? If not, is there a custom study available?
[2014-04-11 22:02:26] |
Not really sure what a Relative Volume study is. Do you have the formula for this?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-11 22:02:38
[2014-04-12 12:19:58] |
Zosimus - Posts: 345 |
This is a custom relative volume study that was kindly shared by Bob Duffy as an Open Source code. Please read and respect the disclaimer at the top of the code. SC Team - the formula to a relative volume study would be: Cumulative volume from session start to current moment/ Average of X days of the Cumulative volume from sessions start to current moment. Usually expressed as Percent. Also there are some Relative volume studies that compare the volume of each bar to the average volume of this specific bar X days back but this is less useful in my opinion. |
relVolume.cpp - Attached On 2014-04-12 12:16:05 UTC - Size: 4.7 KB - 669 views |
[2017-04-16 09:53:59] |
For the record Sierra Chart does have this now: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s356 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
