Date/Time: Sun, 13 Sep 2026 14:31:13 +0000
Rithmic direct feed
View Count: 1519
| [2022-01-01 11:07:38] |
| User266036 - Posts: 29 |
In level 3 with Sierra Charts Is another level Better? I see I have a TransAct WS live feed. What is the best live feed service. I see there is a Denali, CQG, and an Interactive Brokers I know nothing about them I have not had any issues with my orders but will upgrade if there is one Thanks |
| [2022-01-01 14:43:04] |
Do not use the Rithmic data feed. You will have issues with historical data. The very best and the most reliable service for both market data and trading is the Teton Order Routing Service: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-01 14:44:30
| [2022-01-01 14:52:50] |
We did a webinar, with a former Infinity broker, about the Sierra Chart Teton order routing service. And it will be out next week. You will get an email about it. We strongly recommend to listen to it. You can also monitor this thread for it: Webinars for Teton Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-04 12:58:13
| [2023-02-13 19:56:31] |
I am applying to Apex Funding and they use Rithmic for trading. Does historical data problems with Rithmic cause any issue in day trading oil or ES? I have level 10 which has Rithmic but cannot get it to do a live feed. Is it possible to use Rithmic live trading feed from their website and keep Teton and Denali--which I really like? (It would be a bit of a problem though with 2 types of trading domes) Suggestions?? I a eagerly await your response. Thanks very much, Larry Ellis |
| [2023-02-13 22:17:51] |
| John - SC Support - Posts: 47854 |
Right now, you are verified as a non-professional for the CME Group through March 15, 2023. Therefore, you are able to get the Denali Exchange Data Feed real-time data for the exchanges that you have active through that date - regardless of what trading service you are connecting to (connecting to an Apex Rithmic account is fine). If you have a live, funded, futures trading account that can be verified by connecting your Sierra Chart software to it, then you will be able to continue to use the Denali Exchange Data Feed as long as you connect to that live account once a month. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Otherwise, after March 15, 2023, you will no longer be able to get the real-time data from our Denali Exchange Data Feed. If you are interested, you can setup an account as per the information at the following link, for a minimal amount to qualify for the CME Non-Professional requirement: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-02-19 19:20:30] |
I have an Apex evaluation account and need a Rithmic trading dom for Apex. I do not like the Rithmic trading dom that Apex provides. How do I use Rithmic with Denali to make this work and still have Sierra charts and trade my live account with Ironbeam? What is the best solution to trade both accounts---Apex and Ironbeam via Sierra charts? I have tried to find a solution but cannot. Thanks, Larry |
| [2023-02-20 19:34:24] |
You need to install a second Sierra Chart on the same computer. Then you will have one Sierra Chart that is connected to the Teton Order Routing Service and the other Sierra Chart will be connected to your Rithmic account for APEX. By having these both on the same computer you will not incur any additional fees and will have the Denali Exchange Data Feed to both installations. Refer to the following information for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Then follow these instructions to connect that Sierra Chart to your Rithmic account: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-05-07 12:50:31] |
Can I use 3 personal Apex trading accounts using Sierra chart level 10 Rithnic feed for Rithmic Pro Trader. Do I need an addition Sierra chart account to trade my personal account? I want to use Sierra Chart trading dom for both How do I trade my Apex Funding accounts and my personal account simultaneously" |
| [2024-05-07 13:13:28] |
| Sierra_Chart Engineering - Posts: 24850 |
You just need one Sierra Chart account. This is all. You will need to install multiple installations of Sierra Chart for every connection to Rithmic that you need. Each connection though to Rithmic can contain multiple accounts. This depends upon how it is set up on the Rithmic side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-05-07 15:03:30] |
I cannot get Rithmic to connect. I have level 10. It ask for a user name and password which I filled to no avail I have Teton now which is the only one working I want this to work Also I am not sure how to download Sierra Chart for each of my accounts with Apex Trading. I may add one with Topstep also, but still is with Rithmic Pro Thanks for the help. I cannot use 4 trading doms--two max Larry |
| [2024-05-07 15:24:28] |
Are you getting an error when connecting to Rithmic? If you are getting a "Permission Denied" error, then refer to the following: Rithmic Trading Platform Service: Permission Denied Resolution Procedure You can have 3 installations of Sierra Chart on the same computer all receiving the data from our Denali Exchange Data Feed at the same time. To install another Sierra Chart, follow these instructions: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart If you need more than 3 installations, then you would need to have a second computer and you can then have another 3 installations of Sierra Chart on that second computer, but you would have to pay a second set of exchange fees. Refer to the information regarding connections for the Denali Exchange Data Feed here: Denali Exchange Data Feed: Connections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-05-07 19:26:17] |
HERE IS NOTHING STATED AS "Permission Denied" error. ii LEFT NOTHING OUT S STATED THE ONLY NOTICE WAS INCORRECT PASSWORD WHICH i TRIED TO REMEDY BUT COULD NOT thanks, Larry |
| [2024-05-07 19:52:01] |
This time I did get permission Denied" I will refer to your download page info Thanks
| [2024-05-07 20:33:26] |
i CONNECTRD TP sc--ALL SERVERS WITH LIVE FEED, BUT TRIED NOT WITH RITHMIC. i TRIED aPEX USER NAME AND PASSWORD AND SELECTED riTHMIC PAPER TRADING NON--AFGGREGATED--denied access
| [2024-05-07 21:03:29] |
This is a Rithmic issue and there is nothing we can do to help with it, apart from the information we have already supplied. Our recommendation is to ask Rithmic about this.
| [2024-05-07 21:38:35] |
| User150671 - Posts: 80 |
Try Selecting the correct server: Apex-[Location Name closest to you]-Non-Aggregated |
