Date/Time: Sun, 24 Nov 2024 05:44:40 +0000
Dom display request
View Count: 3083
[2013-04-24 17:04:19] |
User22396 - Posts: 191 |
is it possible to have the ability to box the best bid/ask on the Dom? for markets with a wider bid ask spread it would help to be able to see it http://imgur.com/ztAc5kD thanks |
[2013-05-26 19:50:08] |
hello support ...any thoughts on adding this functionality? thanks again |
[2013-05-28 00:25:01] |
We are not able to take new suggestions now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-28 00:25:15
[2013-05-28 13:00:18] |
norvik_ - Posts: 106 |
sfdfgsdfg
[2013-05-28 14:21:11] |
ganz - Posts: 1048 |
User22396 hi try this study as the workaround gd lck Date Time Of Last Edit: 2013-05-28 14:30:57
Attachment Deleted. bbo_b1.dll - Attached On 2013-05-28 14:30:55 UTC - Size: 81 KB - 933 views |
[2013-05-29 13:24:19] |
thanks for the study ganz tho i couldnt get it to plot on the dom?
[2013-05-29 13:31:02] |
User22396 hi Open a TrDOM Chart -> Studies -> Add Custom Study -> bbo_b1 Choose Region 1 for this study gd lck |
[2013-05-29 15:18:44] |
Carl71 - Posts: 125 |
Excellent! Are you able to control the font size? Thanks Date Time Of Last Edit: 2013-05-29 15:19:01
[2013-05-30 03:52:47] |
Carl71 hi do you mean the font size for bbo price values separately? - no ps: thanks for the feedback :) gd lck |
[2013-05-30 20:50:51] |
thanks ganz...got it to work...closest thing to my box request
[2013-09-23 15:09:23] |
Al SC Developer - Posts: 434 |
In ver 1028, there is a new option within Global Settings >> Graphic Settings: * "ChartDOM Best Bid/Ask Box Background" and "TradeDOM Best Bid/Ask Box Background" - these allow a box to be highlighted between the best bid and best ask prices within the price column. Note, in addition to setting the color, these options need to be enabled (using enable check box). Date Time Of Last Edit: 2013-09-25 13:23:44
[2014-01-30 22:43:12] |
bwalks123 - Posts: 122 |
Any chance that the highlighted box for the best bid/ask can actually be in the bid/ask size columns instead of the price column? That would be a great addition and extremely helpful as it is kinda easy to get lost when the DOM is moving during high vol times.
[2014-10-14 21:44:42] |
Viacheslav Malafeev - Posts: 88 |
bwalks123, +1. Is it possible to highlight the best bid/ask in the recent bid/ask columns?
[2015-03-09 14:04:56] |
Any update for this? any chance this can be included in the next SC update? Would be really helpful to be able to highlight the best bid/ask in the buy/sell columns and not the price column.
