Date/Time: Mon, 28 Apr 2025 20:15:01 +0000
Sierra Chart Czech Language Build
View Count: 4456
[2013-03-22 00:03:02]
We have one user who has translated the menu commands on Sierra Chart to the Czech language. It can be downloaded with this link:
http://www.sierrachart.com/downloads/SierraChartSetupCzech.exe
This version is not always the very latest Sierra Chart version but we will keep it up-to-date as often as we can.
The characters used on the menu commands are part of the standard ANSI character set. Since Sierra Chart does not support Unicode, they do not use the extended characters.
If you have any problems, please let us know.
Date Time Of Last Edit: 2013-03-22 00:03:20
[2013-03-28 21:58:47]
You're welcome.
[2013-04-02 03:10:32]
No.
[2013-04-02 07:25:13]
ganz - Posts: 1048
Hello.
Does it mean only 7-bit character sets are accepted?
If it isn't. - Could you share the whole list of phrases to translate it side-by-side?
Thank you.
