Date/Time: Fri, 25 Apr 2025 13:26:40 +0000
Range Bars
View Count: 1952
[2019-12-28 01:48:12] |
wingz - Posts: 121 |
I've opened a 7 point range chart in the ESH0. The candlestick bars are not printing consistently at 7 points. Some of them are 3 points......some of them are 4 points.....some of them are correct at 7 points. I've been using range charts for a long time and have never seen that happen. I just downloaded the current version and nothing changed. I also opened a fresh charts and changed it to a 7 point range chart and it's doing the same thing. Can you tell me what the problem is?
[2019-12-28 05:20:58] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-28 05:57:34] |
http://www.sierrachart.com/image.php?Image=1577512522282.png I've marked 3 bars with arrows and the number of points the bar printed. |
[2019-12-29 04:05:27] |
Refer to this section here in regards to this: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent: Range Bars Do Not Have Specified Range Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
