Date/Time: Thu, 21 Nov 2024 23:44:36 +0000
Rithmic Europe
View Count: 4710
[2013-11-20 16:07:23]
LUCA_SIERRA - Posts: 8
Hi I'm trading throught Sierra Charts with Rithmic datafeed.
Lately I had some problems with the feed due to a low internet speed.
I mean if I ping a server in Italy I get a great result but if I ping and mesure the connection speed with an IP in Chicago I get a very poor result.
At rithmic they suggested me this:
"Since you are connecting from Italy to our servers in Chicago, we can offer you a connect point in Ireland which will be closer to you and might be more stable. You would need to either configure this in Sierra Charts or work with Sierra Charts to set this up. Let me know "
How can I do it with Sierra?
they also sent me the Configuration and Parameters for "Rithmic 01 -Europe":
Configuration and Parameters for "Rithmic 01 - Europe"
We recommend that you use the configurations below as we have specified them.
These configurations require you to be able to resolve the hostnames listed
below which are resolvable on the public internet by DNS.
For C++ Rithmic APIs :
REngineParams :
REngineParams.sAdmCnnctPt : "dd_admin_sslc"
REngineParams.envp : The following variables need to be present :
* MML_DMN_SRVR_ADDR=ritpz01001.01.rithmic.com:65000~ritpz01000.01.rithmic.com:65000~ritpz01001.01.rithmic.net:65000~ritpz01000.01.rithmic.net:65000~ritpz01001.01.theomne.net:65000~ritpz01000.01.theomne.net:65000~ritpz01001.01.theomne.com:65000~ritpz\
01000.01.theomne.com:65000
* MML_DOMAIN_NAME=rithmic_prod_01_dmz_domain
* MML_LIC_SRVR_ADDR=ritpz01000.01.rithmic.com:56000~ritpz01001.01.rithmic.com:56000~ritpz01000.01.rithmic.net:56000~ritpz01001.01.rithmic.net:56000~ritpz01000.01.theomne.net:56000~ritpz01001.01.theomne.net:56000~ritpz01000.01.theomne.com:56000~ritpz\
01001.01.theomne.com:56000
* MML_LOC_BROK_ADDR=ritpz01000.01.rithmic.com:64100
* MML_LOGGER_ADDR=ritpz01000.01.rithmic.com:45454~ritpz01000.01.rithmic.net:45454~ritpz01000.01.theomne.com:45454~ritpz01000.01.theomne.net:45454
* MML_LOG_TYPE=log_net
* MML_SSL_CLNT_AUTH_FILE=rithmic_ssl_cert_auth_params (full path to file)
* MML_SSL_CLNT_CERT_FILE=rithmic_ssl_client_params (full path to file)
* MML_SSL_CLNT_KEY_FILE=rithmic_ssl_client_private_key (full path to file)
* USER=my_user_name (put your user name)
Login Params
* LoginParams.sMdCnnctPt : "login_agent_tp_aws_europec"
* LoginParams.sTsCnnctPt : "login_agent_op_aws_europec"
* LoginParams.sIhCnnctPt : "login_agent_historyc"
* LoginParams.sPnLCnnctPt : "login_agent_pnl_aws_europec"
* LoginParams.sOrCnnctPt : "Not currently available"
Please let me know I I can configure Sierra to hit the Rithmic presence in Ireland
Regards
[2013-11-21 09:20:42]
We have to set this up for you.
[2013-11-22 13:43:10]
Hendrixon - Posts: 130
I've known about this POP almost 2 years now.
Glad to see it finally ready to go live.
Great news.
[2013-11-23 15:24:06]
Ok, tks.
Tell me what I have to do.
Will you send me a file?
please let me know asap
regards
[2013-11-24 01:13:55]
We will set this up now. You will see a new Server choice for Rithmic for this connection.
Date Time Of Last Edit: 2013-11-24 01:14:06
[2013-11-24 07:38:17]
This is now released in the latest prerelease. You will see a new Server setting for Rithmic 01-Europe.
It appears to work properly.
