Date/Time: Mon, 21 Apr 2025 13:11:34 +0000
Replay charts on Linux/Wine
View Count: 2841
[2013-11-15 11:00:03]
ganz - Posts: 1048
Hello SC Support.
ver 1046 non-CLR on Linux/Wine.
At this moment I have no problem with it and it works fine but there is a tiny issue w Replay.
Everything works fine when the Replay was used for a very first time.
If one closes Replay dialog and starts it for the second time then an issue takes place.
This popup window: http://s18.postimg.org/8t6nhh6zt/rpl1.png
Jump and Speed fileds stay empty after that: http://s18.postimg.org/4y39ewnu1/rpl2.png
This info is presented just for a consideration.
Thank you.
Date Time Of Last Edit: 2013-11-15 11:06:36
[2013-11-15 13:51:14]
ganz - Posts: 1048
Also this is from the Log:
Notice: The study TD Moving Averages has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-11-15 07:13:58
Notice: The study Show OHL or C of Time Bars has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-11-15 07:13:58
ty
[2015-03-10 14:09:48]
VPhantom - Posts: 18
ganz - Have you ever made progress with this issue?
[2015-03-10 14:12:19]
ganz - Posts: 1048
VPhantom
No. I'm using win2008r2 for a Replay mode.
[2015-03-10 14:13:59]
ganz - Posts: 1048
VPhantom
... and I hope to see the native linux SC version in one year or so :)
[2015-03-10 15:16:52]
Native Linux is in the works? I had no idea. I'd pay a premium for that!
[2015-03-10 15:36:00]
From what custom studies file are these located in?
[2015-03-10 16:01:41]
ganz - Posts: 1048
SC Support
The studies were the user contributed studies:
TD Moving Averages
It was more then a year ago. Everything looks good now.
thnx.
[2015-03-10 16:03:09]
OK, yes we see we were responding to an old post.
[2015-03-10 16:06:31]
My fault: I was inquiring about the status of the "Encountered an improper argument" replay issue. I simply make sure not to close it, but was wondering if a work-around (besides restarting SC) had been found. :)
[2015-03-10 16:12:53]
There is no workaround. We are not sure why this happens.
[2015-06-07 10:45:34]
User679073 - Posts: 2
ganz помоги пожалуйста!!!!!!!!!!!!!!!!1как избавится от этой проблемы вчера все работало сегодня перестал работать индикатор,что за фигня.
[2019-10-22 15:57:47]
ganz - Posts: 1048
v.2000
looks as something was fixed.
