Date/Time: Mon, 21 Sep 2026 17:25:54 +0000
New Spreadsheets formulas sometimes cause SC to crash
View Count: 2235
| [2015-05-10 17:01:10] |
| Sawtooth - Posts: 4354 |
This thread is a continuation of the off-topic here: New Spreadsheets font is erroneously bolded in v1252 I just had SC crash a 3rd time when entering formulas. Here is a recap of the 3 incidents: 1) -I entered a not-very-complex formula and received a #SYNTAX! error. -I visually and carefully verified the syntax and it was correct. -I pressed Enter again (or OK, I don't remember) and SC crashed. 2) - I copied a formula from another cell with Ctrl-c and pasted it is a different cell with Ctrl-v - I pressed Enter again (or OK, I don't remember) and SC crashed. 3) - I copied a formula from a cell with Ctrl-c and pasted it is a different cell with Ctrl-v - I pressed Enter and only the cell in row3 updated (no cells below updated) - I edited the formula to change one column reference, pressed Enter and SC crashed. The attached pic is related to this. I changed column BS to AK in the formula. |
Private File |
| [2015-05-10 17:54:56] |
OK, I can reproduce a sequence of actions that crashes SC. -Copy/paste a formula from AK3 to AJ3. All cells in column AJ update. -Copy/paste a formula from AN3 to AK3. All cells in column AK update. -Edit formula in AK3. Only cell AK3 updates, cells below have orange triangle but no values. -Focus the chart and Recalculate. -SC crashes. |
| [2015-05-11 20:17:00] |
We will be working on this on Tuesday this week.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-11 20:17:08
| [2015-05-12 17:41:18] |
| Jeffrey - Posts: 2432 |
I am working on this now, but have so far been unable to reproduce the issue. I'm guessing the issue has to do with a specific type of interaction among a set of formulas and how they reference each other. Could you post a spreadsheet file with which you have managed to reproduce the crash?
| [2015-05-13 05:04:13] |
I've responded via email. |
| [2015-05-13 05:13:12] |
In v1254 (New Spreadsheets), I can also cause SC to crash if I go to Analysis >> Studies >> Add Custom Study. It doesn't happen in v1254 (Old Spreadsheets), however, it is slow presenting the list. |
| [2015-05-13 05:29:23] |
In v1254 (New Spreadsheets), I can also cause SC to crash if I go to Analysis >> Studies >> Add Custom Study. This is unrelated. Delete the UserContributedStudies.dll file in the Sierra Chart Data Files Folder.
| [2015-05-13 13:19:59] |
I've deleted the UserContributedStudies.dll file in my nonCLR installation and SC still crashes when I go to Add Custom Study. |
| [2015-05-13 22:07:58] |
Therefore, refer to help topic 17.3: http://www.sierrachart.com/index.php?page=doc/helpdetails17.html#h17.3 There is another DLL file causing the problem. Once again this is not related to spreadsheets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-13 22:08:51
